Old 12-18-2013, 08:31 AM   #1
cam.man67
cam.man67's Avatar
Unusual Braking Issue?
I've never experienced anything like this before. The Scottsdale is optioned with heavy duty brakes and the vacuum assist looks like it comes off the power steering pump?
Anyways, the problem: at random times, the brakes are intermittently either working perfectly or my foot is all the way on the floor. The pedal travel is uneven, sometimes (maybe 1/2 the time) they grab when i just barely put on any pressure. Other times, not so much. I mean, the truck still stops regardless, but it's a little concerning to have your foot go all the way to the floor at random moments.
What could be causing this? My dad think it's air in the brake lines, but I'm not sure that's it.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 12-18-2013, 08:11 PM   #2
donut
donut's Avatar
Re: Unusual Braking Issue?
Ok, vacuum off the PS pump, probably not. However, Hydroboost does run off the hydraulic system.
Is this a recent problem?
Air in lines, possible, but how did it get there? Inspect all the brake lines, looking for wet spots. Also look at the drums and see if the bottom of the drums are wet, (wheel cylinder) or anything out of the ordinary on the calipers.
You could try bleeding, at least there will be fresh fluid in the lines.
Rule out the cheap stuff first.
Actually questioning master cylinder, but rule out the other stuff first.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 12-18-2013, 08:19 PM   #3
Sodell
Sodell's Avatar
X2, if you check for fluid, and air in lines, and find none, I would bet it's the master cylinder.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 12-18-2013, 09:07 PM   #4
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Wink Re: Unusual Braking Issue?
It's more likely to be the actual Hydrobooster this is the component that is located between the fire wall and the master cylinder it is connected in series to the power steering pump and box and it is probably bypassing internally causing the problem you discribed.
Sometimes they will get so bad that if you try to brake and steer at the same time you will loose one and the other will overtake the pressure.
Just to be clear the Hydroboost system is not connected to the braking hydraulic system. It only assist in actuating the master cylinder piston.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 12-18-2013, 09:19 PM   #5
cam.man67
cam.man67's Avatar
Hmm. I'm not losing any brake fluid. At least, I haven't seen any wet areas. So...Hydroboost. Can I just remove it and hook the master straight up to the firewall? Or do I need to replace it?
Old 12-18-2013, 09:48 PM   #6
87 STEPPER
87 STEPPER's Avatar
I guess you could do that but I wouldn't reccomend it cuz then you would'nt have any power assist. I would take it to a known good brake shop and let them trouble shoot it for ya.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 12-28-2013, 01:58 PM   #7
cam.man67
cam.man67's Avatar
So the braking problem is still there, I figure I need to get this straightened out before it gets worse. What part number should I be looking for?
Old 12-29-2013, 10:32 AM   #8
donut
donut's Avatar
Afaik, the part hasn't been identified yet...
