Old 12-18-2013, 03:35 PM   #1
GAc10boy
GAc10boy's Avatar
'Bout to buy some wheels! What backspacing?
Looking to buy some 20" wheels for my '71 stepper - 20x8.5 up front (255/40/20) and 20x10 in the rear (275/40/20).
Planning to go 4.5/6 static for now but would like to be able to bag it in the future and tuck the tires.
What backspacing should I go with?
Just for reference, I'm looking at the Ridler 695s but that could change.
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 12-18-2013, 04:19 PM   #2
ksshane
ksshane's Avatar
Re: 'Bout to buy some wheels! What backspacing?
Sorry I cant just answer your question.
You could contact ksbrktracer. He is a vendor here and can help you with the backspacing and has some really good deals on these wheels.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 12-18-2013, 04:51 PM   #3
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Just ordered the same sizes for my bagged 72, and went with 20x8.5(5.25 BS) and 20x10 (5.5 BS)
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 12-18-2013, 05:01 PM   #4
STP67-72
STP67-72's Avatar
Ask n2billet or Lolife on a bagged stepside with 10 inch rears. Even with the narrow 69 and earlier rear end the 10s are a problem. I have them on my stepper and have since ordered a 9 inch rear. They both tried to tell me that a 10 wouldn't work without mini tubbing....
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 12-18-2013, 07:26 PM   #5
GAc10boy
GAc10boy's Avatar
Maybe I just need to go 22x9 in the rear and trim the lip.
- Robbie
Old 12-18-2013, 07:38 PM   #6
STP67-72
STP67-72's Avatar
That's what I ordered the second go round. 22x9 wheels. Pm one of the two I mentioned earlier, they both had stepsides and can tell you what BS to use. Somebody else may have info also.
68 Chevy swb fleet
07 SS Trail blazer
Old 12-18-2013, 07:49 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
6" rear static drop on a stepside bed with the wider 71-72 rearend,... will need a 8.5" wide wheel with a 5.25" backspace to completely clear the stepside fender lip.
This is with an adjustable track bar to center the rearend.
Bagged trucks need more bs to fully tuck into the tiny rear fender when air'd out.
10" wheels require a mini tub.
This is member hot trux old static dropped truck with the above mentioned 8.5" wide wheels.
Keith
Convert to disc brakes.
Old 12-18-2013, 07:50 PM   #8
lolife99
lolife99's Avatar
Fleetside beds are a whole different set of sizes and numbers,...
Keith
Old 12-18-2013, 08:48 PM   #9
GAc10boy
GAc10boy's Avatar
Might need to give that some serious thought.
- Robbie
Old 12-18-2013, 08:49 PM   #10
GAc10boy
GAc10boy's Avatar
6" rear static drop on a stepside bed with the wider 71-72 will need a 8.5" wide wheel with a 5.25" backspace to completely clear the stepside fender lip.
Thanks, Keith. Very helpful info! Always highly value your opinion as well as many others on this forum.
- Robbie
Old 12-18-2013, 10:27 PM   #11
GAc10boy
GAc10boy's Avatar
Wonder how a 22x9.5 wheel with 5.75 backspacing would fit in the rear (trimming the lip of course)? I don't fully understand how it all works but I know Stella Mae and Raul's stepper both run 22x9 with 5" backspacing.
If I could get the width to work, would the backspacing work without a spacer? Thinking I'll be just going with a 4.5/6 static for now.
- Robbie
Old 12-19-2013, 02:41 AM   #12
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I had the later (longer) rear end in my 68 stepper and I used 20x8.5 5.25 bs with 255/40-20 front tires and 22x9 5.5 bs and 265/40-22 rear tires. Unless you put a wheel tub in the bed that is about the largest wheel/tire you will want to use.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-19-2013, 02:43 AM   #13
C10_ustacould
I'm pretty sure Stella Mae has an early (short) rear axle.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-19-2013, 07:01 AM   #14
lolife99
lolife99's Avatar
Correct.
Keith
Old 12-19-2013, 09:13 AM   #15
CC69Rat
CC69Rat's Avatar
I had a 20x8.5 with 4.75" BS on a short rear housing, so if my thinking is correct (not enough coffee yet) that's close to the same as a 22x9 5" BS on a short housing .. .5" wider wheel, .25 difference in backspacing .. .75 on the housing. I think that's right. Anyway
255/45/20 and it was just about perfect. It was maybe 3/8" off the lip of the fender, no trimming and would tuck pretty good. Aired out might be a different story but, just sayin.
Raul has a 22x9 5" BS with 265/40/22 on air and it is dead sexy. Not sure if he trimmed the fender lips or not.
If you could find a 67-68 rear housing it would open up a lot more options for you with wheels 'off the shelf' rather than getting into custom spec billets. Unless that's what you want of course. IMO an early housing is almost a necessity with a bagged stepper.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-19-2013, 01:14 PM   #16
GAc10boy
GAc10boy's Avatar
I love this truck! Certainly a motivator for me and an inspiration for the quality of truck I'm trying to build (even though you started with a much better foundation).
- Robbie
