Old 12-18-2013, 10:21 PM   #1
thumper56
Source for captive (door hinge) nuts
Anyone know of a source to purchase captive nuts with flanges to spot weld into my 56 door jambs?
Haven't measured or checked thread pitch yet, but everything I've found while browsing is too small.
Thanks and happy holidays!
thumper56 is offline   Reply With Quote
Old 12-19-2013, 12:12 AM   #2
67GMCkid
67GMCkid's Avatar
Re: Source for captive (door hinge) nuts
Have you looked here?
http://www.grainger.com/search?searchQuery=captive+nuts
67GMCkid is offline   Reply With Quote
Old 12-19-2013, 12:22 AM   #3
sqrlnts
Hey Thumper, if you have a welder you can make your own, if you want. Then you can use whatever size bolts/thread you want. Just cut a square/rectangle metal tab drill a hole in the middle (that will allow the size bolt you want to use to pass through the hole) and weld the nut to the tab.
sqrlnts is offline   Reply With Quote
Old 12-19-2013, 02:02 AM   #4
Donaldo
Nuts, for all kinds :)
http://www.mcmaster.com/#nuts/=pvcyqh
Donaldo is offline   Reply With Quote
Old 12-19-2013, 08:13 AM   #5
fabguy
Elev8r Man
fabguy's Avatar
Original ones i believe are 3/8" fine thread.
I made some out of unistrut nuts. They are 3/8" standard thread. As for the cage I took some tubing and sliced it down the side, drilled a larger hole for the bolt to pass through dropped in the unistrut nut then welded the sliced tubing behind the bolt hole. Just make sure the nut has room to slide a little.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 12-19-2013, 08:24 AM   #6
Russell Ashley
Russell Ashley's Avatar
My local Ace Hardware store carries them.
Russell Ashley is offline   Reply With Quote
Old 12-19-2013, 08:38 AM   #7
Rude Dude
Rude Dude's Avatar
Mark K the people in Oklahoma that sell bed parts carried them
Rude Dude is offline   Reply With Quote
Old 12-19-2013, 11:15 AM   #8
Speedbumpauto
Speedbumpauto's Avatar
Go to McMaster-Carr website. They call them weld nuts. Click on NUTS then click on WELD NUTS, then scroll down to Easy Align nuts. I used the 3/8x24 steel with steel cage. You have to drill a hole in the jam for the plug weld, hold the nut in place tightly with a short bolt, weld, grind and they look almost factory.
Speedbumpauto is offline   Reply With Quote
Old 12-19-2013, 11:36 AM   #9
Kim57
Kim57's Avatar
I think this is what you mean.
http://www.mcmaster.com/#captured-nuts/=pvkdgu
The only problem with these is they don't have as much adjustment as the originals.
I think the door bolts are 3/8-24 but you should check that.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-19-2013, 01:55 PM   #10
OrrieG
OrrieG's Avatar
If you are not striving for originality and you only have one that is bad (like me) they are all accessible from under the fender or after removing the kick panel.
OrrieG is offline   Reply With Quote
Old 12-19-2013, 07:25 PM   #11
_Ogre
_Ogre's Avatar
i made mine out of flat bar
shop air compressor timer
Old 12-19-2013, 09:16 PM   #12
thumper56
Thanks for all the great ideas folks! Yep, here in the boonies of VT I hadn't found anything locally, and was hoping to save some time by not fabricating.
I use McMaster-Carr and Grainger all the time for stuff at work, but never thought about them- DUHHH.
Old 12-19-2013, 10:13 PM   #13
Donaldo
FYI - Grainger gets a lot of their hardware from McMaster-Carr....why pay some middle person to mark it up ?
