Old 12-19-2013, 01:10 AM   #1
yossarian19
Cherokee rear shocks for TF trucks?
Just a thought.
The travel numbers (12 1/4 compressed, 20 1/4 extended) and vehicle weights (about 3400 lbs) line up pretty damn close between an 84-01 Jeep Cherokee and a 55-59 Chevy 3100 / 3200. The mountings are almost perfect - you'd have to press a bar pin out of one end of each Cherokee shock. Note that the rear shocks from a Cherokee will work, the fronts have a different mounting type.
With POL charging $90 a corner for Bilsteins (which isn't bad, btw) I had to look around a little. You can get all sorts of shocks for Cherokees, including KYB Bilstein Monroe and Gabriel just to name a few. As cheap as $20 a corner.
For original ride height or lifted, I think this is a win.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 12-19-2013, 08:51 AM   #2
Katrina/10
Katrina/10's Avatar
Re: Cherokee rear shocks for TF trucks?
I used some shocks for a Jeep Grand Wagoneer on the back of my 55, they fit perfectly.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 12-19-2013, 02:08 PM   #3
OrrieG
OrrieG's Avatar
Mine ended up being the same as the donor truck (74K10) with a 4" lift. I obvoiusly had to modify the frame mounting brackets on both ends.
OrrieG is offline   Reply With Quote
