Tilt Column Disassemble
I just bought a tilt column. Even though it's in pretty decent shape, I'd like to freshen it up a bit before it gets installed.
Anyone have an exploded view of the column that they wouldn't mind sharing? Initially; I tried to start at the lower end to disassemble, but it appears it disassembles from the top down. Does it require a special puller to remove the component in the top? Lastly; there is only one number on this unit (A1 343). My OE column has no part numbers stamped in it. It appears to be the same length, and the shafts are the same diameter, but the punched openings are slightly different. Anyone know what the A1 343 may mean?
A man's thoughts devise his ways; but it's GOD that directs his steps. |
Re: Tilt Column Disassemble
Unless it's messed up , I'd leave alone it not familiar with it . There is a puller to get tilt pins out yes . Lots of small parts too. I've had dozens of gm column apart. All basically the same back then. Sorry can't help with exploded view but did a quick search this might help. http://www.nastyz28.com/tech/e-tiltcol.html
Only puller required is for the steering wheel. A simple screw can be used for the collar pins. Done it several times. Do a search for threads on this, plenty on it. If the tilt part of the column isn't sloppy best to leave it together.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: Oct 2010
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
![]() Join Date: Jun 2012
Here are the instructions i got from another thread. The hardest part was removing and installing the shift tube and lock plate, but other than that it was not to bad. I didn't need any special tools.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
![]() Join Date: Mar 2012
I would get a hold of kevsclassic on here maybe he could help out or even refurb it for you, I bought one from him this year and it was awesome.
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Thanks everyone for all your help, and especially sharing photos. I have saved the photos, and the step by steps.
It's greatly appreciated.
JJH Jimmy.........In the second photo in your post; is the bearing supposed to fit inside the adaptor?
How did you remove the bearing fron shaft? Must I remove the top pieces and bring the shaft out of the tube? I'm trying to be delicate because I'm concerned about distorting the tube, or worse yet, damaging the bearing and adaptor. Are these parts available anywhere?
#9 | |
#10 | |
That makes sense when you said it "snaps" onto the bearing. Now I know I gotta get the bearing off and the adaptor out to get them back together. Thanks again.........
If you come up with a good way to get a new bearing into a new adapter let me know. I had all new parts and ended up breaking the plastic adapter trying to get them back together. I might have to try another vendor for the plastic bushing. I realize it is supposed to be tight but after I got the bearing in my bushing it was split a 1/8 inch.
You are sooooo right! I alamost had it on when I heard that sickening snap.
Yep; cracked open on the side opposite where I was working. Turned around, walked in the house, and turned on the TV. After about 3 hours I'm thinking I'll look at it after I put it on the bearing. Since the tube actually holds it in, I may try JB Weld to seal the crack. If you look in the last post from JJH Jimmy, he said he bought a new one at LMC. I looked, haven't seen it in their catalog yet. BTW.....Going to try heat to swell the inner race on that pesky lower bearing so I can remove it and pack it or buy another. This thing ain't budging no way no how. Yeah right, we'll see how that works out.
#13 |
That is a good idea on the JB weld, never thought of that. I think the tube does most of the holding as well but I cant stand having that crack in there.
Funny you mention that once it happened you went into the house and watched TV. I did the same thing, lol |
