12-19-2013, 11:23 AM | #1 |
door light switches for dome (interior) light
Does anyone know how to wire the door switches to activate the dome light to come on when you open a door? I have the switches but there is no wiring inside the door jamb where the hole is for the switch at least I haven't found it.
12-19-2013, 11:50 AM | #2 | |
The Older Generation
Re: door light switches for dome (interior) light
There will be a small hole in the kick panel above and behind the emergency brake pedal assembly. See if the wire is there. It will be a small white wire. There should be one on the passenger side too. If you don't see the wires then someone probably removed the wire loom. If I remember correctly the wires from each side are crimped together at the fuse block and plug into a wire harness there. Let us know what you find. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-31-2013 at 05:31 PM. |
12-19-2013, 12:10 PM | #3 |
thanks i will look for those wires.
12-19-2013, 12:45 PM | #4 |
If I remember right, 67's, or early 67's did not have them. If your cab does not have a flat bump out at the front of the door jam where you would normally expect to find the switch, you won't find the wiring either. My truck does not have them.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-19-2013, 12:54 PM | #5 |
My truck is a 71 and the hole is there to mount to switch but on the wiring diagram i have there is no reference to this switch. Thanks for the information.
12-19-2013, 09:08 PM | #6 |
Do a search in the electrical section. Lots of info on this subject. Courtesy lights and dome lights are not like the other lights in the truck. The white wire is ground and the orange is the power. The headlight switch is the best place to find the correct wires. Both orange and white terminate here. The orange wire also provides power for the brake lights I believe.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 |
12-19-2013, 11:43 PM | #7 |
On my '67, the orange and white wire run down the drivers side next to the hi/lo beam switch. The orange is a constant power to the dome light and this should be left alone.
The ground is how the dome light is controlled. The white wire is the ground for the dome light. You can connect to the ground wire anywhere and make a completed ground and the dome will light up. The switches are designed to complete a ground,(You'll notice only one connection on the switch) so all you have to do is spice into the white wire while leaving the original connection intact, and attach it to the switch. When you open the door, the switch automatically grounds out, making the dome light turn on. Only the white(ground) wire goes to the door switch, the orange wire remains untouched. For the passenger side, you need to run another ground wire to the same white wire. You could run a ground wire under the dashboard or under the carpet, from the passenger switch and connect it to the same wire you connect the driver's door switch. Or you can connect to the white wire at the dome light and fish a single wire from there (in the opposite direction as the original wiring) and connect to the door switch. In a nutshell: Ground out that white wire anywhere and the light will turn on.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
12-20-2013, 10:05 AM | #8 |
Thanks everyone for the information. I should have a lot of time to work on it this weekend. Rain Rain Rain.
12-20-2013, 12:33 PM | #9 |
Cool Truck
I'd like to add a set of switches to my truck eventhally, I've always thought that was a nice feature.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
12-31-2013, 09:30 AM | #10 |
Thanks everyone for the information. Got my lights working last night for some reason on my truck it ended up being the orange wire not the white. Figures that out after I blew a fuse and then put a meter on it and the white was getting the 12V not the orange. Spliced into the orange with 2 wires run from the switches on each door and they both work. Thanks again everyone!
1971 C-10 Short Bed |
12-31-2013, 05:05 PM | #11 |
Project Junkie! Fishing Poor!!
That is the dome lamp extention harness. We sell them, correct factory reproductions no splicing necassary. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
