Old 12-19-2013, 12:30 PM   #1
Shugalou
Shugalou's Avatar
Quadraject Vacum Line ?
Hey Guys,
I'm still getting familiar with this truck (78 stepside) and while I am getting ready to rebuild the carb (first time for me) a couple of things caught my attention.
One of the lines is plugged, in a hack job sort of way and the other looks like it's just open - should the open port be plugged as well?
I also noticed that one of the return lines to the emisions canister is cut I'm guessing this was done to improve performance? Does it effect the reliability in any way?
Shugalou is offline   Reply With Quote
Old 12-19-2013, 12:32 PM   #2
Shugalou
Shugalou's Avatar
Re: Quadraject Vacum Line ?
Here is the canister
Old 12-19-2013, 12:35 PM   #3
Cherub
Cherub's Avatar
right or wrong i remove the emission stuff when i get a new square.
Cherub is offline   Reply With Quote
Old 12-19-2013, 12:41 PM   #4
Shugalou
Shugalou's Avatar
Does it choke performance that bad?
Old 12-19-2013, 02:48 PM   #5
83GMCK2500
No, at least, I don't believe it does. I have left all of my vacuum and fuel vapor lines intact as far as the charcoal canister and whatnot is concerned. The only emissions hardware that I remove is the air pump and it's associated parts, plug the holes in the manifold.
I keep the heat riser valve on the passenger manifold, just make sure it moves freely and that the bellows is sound. I can get in my truck at 0 degrees outside, tap the throttle to set choke, fire it up, let it run, drive it, and after it reaches temp the choke opens and idles fine (after some slight adjustment recently). My truck runs smoothly and warms up quickly and part of me likes to attribute part of that to keeping it almost as Ma General built it.
Do you still have your vacuum hose diagram under the hood? That large port (left one circled) is likely the one that runs to charcoal canister (the cut line you pictured).
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-19-2013, 04:20 PM   #6
Shugalou
Shugalou's Avatar
Thanks 83 GMC
No there is no diagram under the hood and most of that stuff you are referring to in new to me (heat riser valve, air pump) I'm gonna have to dig deeper with my research.
I thought maybe that port was supposed to go the canister, should I block it off
Old 12-19-2013, 04:46 PM   #7
bnoon
Yes, that's the vent line for the carb and stock it goes to the canister. Does not need to get blocked. Either run it back to the canister or tap into the vent line that goes from the canister back to the tank vent and bypass the canister. Just keeps it from smelling like raw fuel under the hood and possibly into the cab that way.
The small plugged line I don't remember. My BBC truck doesn't have it and I can't find my pictures of the SBC truck I had.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 12-19-2013, 09:00 PM   #8
SkinnyG
SkinnyG's Avatar
The circled plugged hose on the right goes to the vacuum advance canister on my '77.
The circled port on the left I do not have on my carb. I do have a port below it on the base, though, which goes to my charcoal canister.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-20-2013, 12:04 AM   #9
mrolds88
Port with the screw in it is for the vacuum advance on the distributor. It needs hooked up.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-20-2013, 03:51 AM   #10
cadillac_al
Port with the screw is ported vacuum. Factory used it for vacuum advance but many people plug it and use full time vacuum for the advance. I'll bet that's the way yours is hooked up.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is online now   Reply With Quote
Old 12-20-2013, 08:24 AM   #11
Shugalou
Shugalou's Avatar
Thanks for the info guys
Looks like ill put the one hose back to the canister and ill locate the vacum advance and see if it runs different when hooked up
It runs ruff sometime and feels like its gonna die at a light at times.
Thanks guys this is an awesome forum!
Old 12-20-2013, 11:06 AM   #12
geezer#99
geezer#99's Avatar
It won't do any good hooking up that top hose to your charcoal canister without setting up the canister correctly.
The Small hose with the screw in it is a ported vacuum source.
Rebuilding your carb might not change how your truck runs now. It runs rough and dies cause of your unheated air to your carb.
Old 12-20-2013, 11:31 AM   #13
Shugalou
Shugalou's Avatar
Thanks Geezer,
I'm gonna have to locate this diagram to find out how it is supposed to be routed. I figure there is no harm rebuilding the carb (provided I don't screw it up). Since I have no idea when it was done prior.
Old 12-20-2013, 12:37 PM   #14
Shugalou
Shugalou's Avatar
OK I think I found the diagram. Does this look like it makes sense?
This is for a 78 350 with 4 Barrel
