12-19-2013, 03:32 PM | #1 |
Blown head gasket?
I think i may have a blown head gasket, I have water in my oil.. and it looks like some smoke around my passenger side exhaust manifold.. I haven't really paid attention to the coolant since i haven't driven it since the motor swap.
Rust is better than rice. |
12-19-2013, 05:06 PM | #2 |
Re: Blown head gasket?
Check your plugs and coolant but I'm going to agree it's blown or cracked. Only oil should be in oil
12-20-2013, 05:42 PM | #3 |
So it's the middle of winter and i don't have a garage... i can't leave it like this though can i won't water in the oil cause rust?
12-20-2013, 06:10 PM | #4 |
Drain all of the coolant including the 2 lower block plugs. Drain and replace the oil and filter. Use cheap oil. It isn't going to see much use. Don't add any coolant back. Start and idle just a few seconds longer than it takes to get full oil pressure then turn off. Should be good until better weather.
12-28-2013, 04:11 PM | #5 |
do you have a picture of the block plugs i'm not sure exactly what they look like.
12-28-2013, 08:23 PM | #6 |
They are just above the oil pan rail about half way back the block. Usually 1/2 or 9/16 hex head.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
12-29-2013, 04:06 AM | #7 |
those probably aren't coming out then... I tried to remove some for my knock sensor and oil pressure switch and they are stuck good.
