Old 12-19-2013, 03:55 PM   #1
solidaxel
solidaxel's Avatar
Very Rich condition
Just started this 5.3 with a new Howell harness and reprogram from them.
Injectors have been sent out a flowed at 79 Ml.and cleaned, along with a new regulator.
Starts and runs but very rich, all sensors O2 and exhaust are in place and new gaskets. Fuel tank and lines are new fuel is fresh.
Cold air filter is in place and the MAF is at 90*.
Pressure is holding at 52# fuel filter is a wix stock.
What to check next?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-19-2013, 11:39 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Very Rich condition
Do you have any codes? Do you have a way to monitor the information in the PCM? Check your temp sensor, I've seen bad ones read -40*, or an open in that circuit will do the same and make it run rich. Could be the tune also, has it always been this way?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-20-2013, 12:17 AM   #3
solidaxel
solidaxel's Avatar
I will check tomorrow
I just got my ELM 327 and Torque Pro to pair, I will look for faults
What should the voltage reading be at the coolant sensor, or how can I test to see if it is working?
LS 3 4L70E
Old 12-20-2013, 03:58 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Does it just smell rich or are you getting a physical indication?
90* is a tiny bit much for the MAF, 10-2 clocking is ideal.
Vacuum leak, unplugged or bad o2.
How does it feel, where does it idle...have your driven it? Very little info to work with.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-20-2013, 08:36 AM   #5
solidaxel
solidaxel's Avatar
It smells very rich
I will re clock the MAF
the O2 are brand new
Sometimes the idle is even, and at times it wants to stall
The vacuum is 15 to 17* at the port on the intake
No I have not driven it yet I am still finishing the suspension while the dog house is off
LS 3 4L70E
Old 12-20-2013, 10:26 AM   #6
Custom 68
Custom 68's Avatar
You really need to scan it. One thing to look for is to make sure you O2 sensors are cycling from basically zero to 800 or so. It will be a nice sine looking wave. I assume when you had the tune and they had all the information I am not sure what the 79 Ml equates to it seems most of the information is in lb/hr.
Like it was mentioned it is hard to tell if it is rich just based on smell, when you first start these they will be rich like a choke at idle. Also check all you fuses and grounds.
Is this stock or have you added a larger cam, those will mess with your idle fuel as well. I wouldnt get too worried until you have scanned it and driven it. That will tell you alot.
good luck
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 12-20-2013, 11:24 PM   #7
Hart_Rod
Hart_Rod's Avatar
If you changed the injectors, your tune MUST be updated with the correct injector data for the specific injectors that you have:
Hart_Rod is offline   Reply With Quote
Old 12-21-2013, 01:25 AM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
That was my thought. Something in the tune needs to be checked and I would think you would have a code of some sort to go by.
dwcsr is offline   Reply With Quote
Old 12-21-2013, 08:28 AM   #9
solidaxel
solidaxel's Avatar
R & R stock injectors and had them cleaned and flow tested.
I did run a scan, but I do not have the codes with me but I think I looked up a few and there were with the Voltage or Alt. I will get more this PM
The engine is all stock 5.3 and the O2 sensors are new and ordered from Howell when I ordered the harness and tune from them.
I sent them the stock computer, gas peddle and TAC they tested and tuned the computer and returned all new items....... plug and play right!!!
LS 3 4L70E
Old 12-21-2013, 08:47 AM   #10
solidaxel
solidaxel's Avatar
Is there a test for the MAF, the AIr cleaner is a new cone looking kit that I received on line, I am going to take the Air cleaner off and start it, see if there is a change.
Maybe get some MAF cleaner and clean the MAF!
LS 3 4L70E
Old 12-21-2013, 07:02 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Get MAF safe cleaners, spray it down. If you sucked in any oil or **** from the KN filter, you could be throwing your MAF off as a result. Also make sure the wires aren't pinched or coming out of the plug.
And get those codes.
Old 12-21-2013, 07:48 PM   #12
solidaxel
solidaxel's Avatar
O K, have some CRC Mass Cleaner did not help.
The only code that came up is P0622!
LS 3 4L70E
Old 12-23-2013, 01:15 PM   #13
Custom 68
Custom 68's Avatar
How's your fuses in the harness
Dave
Old 12-23-2013, 09:29 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
That code pops when the ECM is trying to regulate voltage and gets no result back.
Check for voltage on the dark blue wire, should be over 10v
See if the resistance between terminals is more than 15ohms
Or something in the ECM needs to be changed. Depending on how it was setup, the ecm may be looking to control the voltage, where most of the older truck alternators are internally regulated.
I think Hart Rod had this code and a similar issue on his.
Old 12-23-2013, 09:48 PM   #15
Hart_Rod
Hart_Rod's Avatar
If your alternator is internally regulated, you can set this DTC to inactive.
Old 12-23-2013, 10:24 PM   #16
solidaxel
solidaxel's Avatar
Had it running yesterday and it is a bit better, it did come up with P0171 and P0174
I did take a look at all vacuum connections and then I re torqued the manifold to pipe flange, have new gasket and donut installed I will try again tomorrow
LS 3 4L70E
Old 12-23-2013, 11:00 PM   #17
Hart_Rod
Hart_Rod's Avatar
Do you have your exhaust on?
Old 12-23-2013, 11:14 PM   #18
solidaxel
solidaxel's Avatar
Yes all the way to the back bumper
LS 3 4L70E
Old 12-23-2013, 11:50 PM   #19
Hart_Rod
Hart_Rod's Avatar
I think it just needs a street or dyno tune.
Old 12-24-2013, 10:01 AM   #20
solidaxel
solidaxel's Avatar
.............. 10 - 4, I think it is time to button it up and drive the snot out of it !!
LS 3 4L70E
