Old 12-19-2013, 07:28 PM   #1
Cohl
Cohl's Avatar
Frame looks tweaked?
So I just put set the front clip back on with the rest of the truck and noticed the grille looks tilted. I had just swapped frames and put on new body mounts and the tub and doors were really close to spot on. Just took measurement and the front spring perch is about and inch different between the two front, but the rear two bolts are exactly the same. I realize these frames are not perfect, but is this normal. Is this something not too big a deal, just shim the body and whatnot? Or should this frame have to get some work done?
Cohl is offline   Reply With Quote
