Does this look crooked to you???
Re: Does this look crooked to you???
Place a level sideways across your intake where the carb sits. From what Ive seen... most of the V8's tilt back towards the cab a bit. Should be level sideways though...
When your tranny is hooked up, measure and set your output shaft evenly between the frame rails... it'll parallel your engine with the frame rails
I did the 700r4 swap in my 72 and have centered the rear output shaft in between the frame rails (might be a 1/4" off) in doing so it seems to pull the engine quite off of center. I really fear the frame is tweaked...
I see what you're saying, it does look a little skewed to me too. I think I would do a bunch of measuring to verify before I change anything permanently. I could also be an optical illusion seeing as the firewall is unbalanced with components. Also I think your toe out plays into the illusion as well. Good Luck I hope your frame's not tweeked!!
It (probably) should be offset to the right.
Most vehicles offset the powertrain to provide a little more foot room for the driver rather than the passenger. So - parallel to the frame rails but offset an inch or two. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#7 | |
On a side note anyone ever run newer style small block mounts (80s-90s)? Does it help with header clearance. The headers I have wont clear the mounts or oil filter. |
they run better when not perfectly square in the frame
Thats my next question... I have been fighting my OCD and lack of skills on this build and its taking me way to long to get **** finished. I want this truck to be a driver... not a show truck (I still want it to look decent of course). Is there any major issues with this? As long at the rear output is centered I should be all good? Do you think it will be really obvious when I lift the hood that its crooked?
#10 | |
Engine location is not precise in any car/truck. You can wiggle the engine up/down/left/right a little with a pry bar. I wouldn't worry about it.
![]() Join Date: May 2013
ford explorers are 3 inches off center
#13 |
Project 7dos
Your pics aren't dead on... They almost are, but use the frame for reference I can see more of the inside left frame rail then I can the inside right, which means you were standing more right than center.
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
#14 |
also when standing in front of the truck look at the side windows through the windshield, you can see you aren't directly centered.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#15 |
C/10 junkie
Take on shoe off
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#16 |
![]() Join Date: Dec 2013
Baloney ! That engine is as crooked as a $5.00 attorney ! !
#17 |
Maybe a dumb question... I'm using a the th350 trans mount on the 700r4. Could this cause issues? Do those mounts only go in one way? (Is there a front and back if that makes sense )
#18 |
![]() Join Date: Apr 2012
I think I might know your problem. Remember the frame is like a ladder. If one side is pushed in or out it affects the other. Stand at the front of the frame rails looking side to side and see if they are off a bit. If that's it, just get a come along and pull it back in (diagonally to the opposite rail).
I had this problem and fixing it solved a lot of issues with my body panels that didn't line up right. |
#19 |
C/10 junkie
I believe that the 700r4 can use the same mount. Shouldn't be a problem.
#20 | |
C/10 junkie
#21 |
C/10 junkie
You also need to remember that the drivers side cylinder head sits farther forward than the passenger side which can add to the illusion that it's kinda sideways.
#22 |
#23 |
Still looks crooked to me !, it may run down the road but how well ? spend untold dollars and time and then settle for a somewhat correct power train alignment ?
#24 |
To me it looks like the trans is a bit off to the drivers side, not much but some.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#25 | |
I have a radical idea!
Big block first gen Camaros have assymetrical offset engine mounts to allow clearance for the steering box and power steering components. The engine sat 1" further to the passenger side from the factory. IOW, you have nothing to worry about even if is offset a little bit. As somebody else mentioned, it is often an optical illusion because heads are offset on the block.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
