Sway Bar Bushings
So I have a quick question I hadn't noticed until last night I'm missing 2 sway bar bushings is there a specific brand I should be looking at or a certain size I should look at getting as well?
Also what size rear sway bar is the best overall for our truck? Thanks for the help guys!
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
Re: Sway Bar Bushings
I just got front sway bar bushings from the local auto parts store - forget the brand but they were blue in color - might have been a poly bushing. They made a huge difference in the handling of the truck. I have an 83 C20. I don't know anything about rear sway bars, except that sway bars cost a lot of money at the pick and pulls, front or rear.
Thanks man!! Yeah I didn't notice till last night I have 2 bushings that are completely gone so I just figured it might be a smart idea to replace them.
Not too worried with a rear right at this moment but I have heard that they do wonders too. Isn't the poly bushing, actually the best or advised to buy over just what might be a regular rubber one?
I bought some at the local parts store (rubber) for about $6 bucks for 2... Worked really well.. Then i decided to replace them with the poly. Due to that I had heard that the truck would handle better.. I personally can't tell much of a diffrence.. Im pretty shure they will out lasts regular rubber bushings though..
Will I ever finish my 1986 stepper.. |
Rear bars "bring the rear end around" so to speak, to reduce front end "plow" through a corner. FYI You don't want to just buy the biggest one you can find or afford or you'll loop it the first time you experience trailing throttle snap oversteer.
For bushings, Energy Suspensions bushings is what I used last time on my '86 on the stock front bar and the ride was improved quite a bit, especially going down lumpy county highways.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
Thanks guys does anyone have the original sway bar on there truck and can tell me what size I need to buy? Also do I need to get the greaseable or non-greaseable?
Depends on what engine/suspension package you have (1/2 ton, heavy 1/2 ton, 3/4 ETC.). Measure the thickness of your bar and report those numbers to the parts shop. The end links will be the same most likely no matter which stock size bar you have, but the block mounts on the frame stands will be different between bar sizes.
Okay great thanks bnoon!
I have a Silverado package which from what I've seen is just a 1/2 ton suspension but from what I recall I do have 6 leafs I believe I can verify it when I get home.
#9 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I would recommend the energy suspension kit from summit. They use to different durometor bushings. The end links are slightly softer so the arm can move relatively bind free
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#11 | |
![]() Sway bar end links are not used on stock truck sway bars. They are used in many applications, but not pre 1988 GM trucks.
I would check the LMC catalog for a general reference on size and price. The only criticism I have heard of poly bushings is that they may contribute to a rough ride - mostly on the body mount bushings though. Also, some complain of squeaks on some of the harder bushings. Cheap stock rubber would be a good start since they are easy to change out and you could replace them with poly later if you did not like them. I did remove my bar, then sanded, primed, finish painted gloss black while it was out.
#13 | |
But yes the end (bushings) my bad; are slightly softer. Keeps your front end from riding like a solid axle and bouncing your teeth out.
#14 |
I know the pieces fit
New OE bushings from NAPA will be good and probably the least expensive route, polygraphite bushings from PST get good reviews as well. Not that I have anything against polyurethane bushings, I've used them before and probably will again. Just pointing out the other options.
#15 |
Sorry, my last truck had a front bar by Adco that had end links (custom fit from a 99+ setup).
#16 |
My 87 1/2 ton used the 1 1/16" bar. I put the poly bushings on the frame and the rubber bushings on the ends.
#17 |
X2 on energy suspension! I've had pretty good luck with them. I think the polys are worth a little extra dough. Seem to be pretty freakin durable. Mine get the sh!t beat out of them and they're all holding together well. I've never had any squeaking from mine either...
1976...no...79...Chevy....wait...GMC shortbed 4x4. 5 inch lift on 35s, 355, sm465, daily driver. One day I'll figure out the story in that one. 1957 Chevy long stepper...not sure what I'm doing with that one yet. Awaiting funds I suppose. |
