12-20-2013, 10:24 PM | #1 |
would this work on my 70 c10?
i have manual steering would this bolt up and work?http://newjersey.craigslist.org/pts/4241983265.html
12-20-2013, 11:25 PM | #2 |
Re: would this work on my 70 c10?
You can get a power steering box off of any 2 wheel drive [assuming that is what you have] from 1968- 1987 Chevrolet or GMC truck C10,20 or 30 model. Also the R-V will carry that same box until 1990.[ that is as long as the General made the trucks square. now you must know that some of the newer ones carry a different type of fitting type in the box, it is a metric line but if you get the line for that model truck your good or many companies make an adapter like LEE [they are a industry leader in steering boxes]. Also if you take the the big nut from the back of a newer type pump, that is the pressure regulator it will have the newer type fitting it will screw right into the older pump. Since you don't yet have a pump or box on the truck now and both will have to be bought it might be a good or even a great time to upgrade to a serpentine belt system off of a truck like a 1990 model 350 , they are cheap and plentiful and really look great on our trucks when cleaned up some. Jim
12-20-2013, 11:26 PM | #3 |
Moderator
That is. 67/68 style setup. If you had a 67/68 truck and were going for originality, I would say this is your ticket. Otherwise I would get a power steering box, pump, pulleys and hoses from a donor truck.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-21-2013, 12:08 AM | #4 |
thanks guys i was looking for parts on cl and i saw the ad and my wheels started turning. im going to take your advice and start looking for a donor setup. thanks again!
01-19-2014, 12:55 AM | #5 |
can anyone tell me if the power steering setup from a mid 80s astro van(w/350)would work in my 70 c10. a buddy of mine is junking his van and he has a new pump and rebuilt steering box that i can have as well as anything else
01-19-2014, 01:28 AM | #6 |
The G-series vans have different steering box, but the control arms will work, spindles too. The Astro vans are akin to the S-series pickups, so not much fits, nice steering wheels, though. Power steering pumps are pretty universal in GM-land.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
01-19-2014, 02:18 AM | #7 |
thanks,i figured it was too good to be true.
01-19-2014, 01:41 PM | #8 |
Someone removed that 68 assist for a reason!
01-19-2014, 05:29 PM | #9 |
Hand Crafted C-10
Ram steering is not correct for your truck and, in fact, I've never personally seen it
on anything newer than a very early 1968 (non-dimpled frame). Follow Hugger6933 and LEDDZEPP's advice and purchase an entire system locally or shop here on the parts board for at least the pulleys & brackets that you will need. There is nothing wrong with the ram steering systems (they were good enough for Corvettes!) and can be an interesting addition to your truck if you decide to go that route. A nice write up from member 1967C20 on the subject can be found HERE.
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
