Old 12-21-2013, 11:36 AM   #1
ScottH
ScottH's Avatar
Can a 84-87 tilt column be installed in an 83?
I know this can be done but was wondering what the differences between the 2 columns are. If anyone can shed some light on this I would appreciate any info.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 12-21-2013, 12:28 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Can a 84-87 tilt column be installed in an 83?
83 has dash mounted wiper switch. 84 and newer use column type of switch.
Old 12-21-2013, 12:43 PM   #3
83GMCK2500
Yep. Also, dimmer switch in '83 is on the floor, later ones it is part of the multifunction switch. (Signal, Wiper, Cruise, Dimmer)
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-21-2013, 12:46 PM   #4
ScottH
ScottH's Avatar
Thanks guys, understand the differences with the turn signal switch, just wondering if wiring, linkage, etc. will allow the later model column to be installed in an 83?
Old 12-21-2013, 12:52 PM   #5
83GMCK2500
By virtue of the switches moving around you will have a lot more wiring that connects to the 84+ column. You may have to extend or relocate some of the '83 wiring to reach the '84+ column. The ignition portion didn't change, AFAIR. I feel that a reasonably motivated/experienced person could get a length of harness from the column connector at a junk yard and splice it into their earlier harness.
Cannot comment on linkage, have a 4-speed here.
Devin
New Daily, the '96
Old 12-21-2013, 03:23 PM   #6
nekkidhillbilly
id like a how to on this for a 70s truck myself. post up the hurdles you go through.
nekkidhillbilly is offline   Reply With Quote
Old 12-22-2013, 12:22 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
I gotta do one soon too, 88 to 78....for tilt
havn't got much into it yet
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
