12-22-2013, 12:51 AM | #1 |
Looks like an overdrive 4-speed truck for sale.
Not sure if the option was available in 81 but looks like the shifter knob is the overdrive trans.
http://www.countryclassiccars.com/html/sptrucks_63.htm
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
12-22-2013, 07:12 AM | #2 |
Re: Looks like an overdrive 4-speed truck for sale.
Could be they just stuck that ball on the shifter maybe?
12-22-2013, 07:16 AM | #3 |
With the shifter that far back definitely is not the sm465. Could only be a Saginaw or the O/D a833
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-22-2013, 09:15 AM | #4 |
Cool truck, but if I bought it that steering wheel would be in the garbage the same day.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
12-22-2013, 04:28 PM | #5 |
12-22-2013, 10:21 AM | #6 |
I like the paint it makes the emblems pop. I also really like the tailgate/ taillight section.
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
12-22-2013, 01:18 PM | #7 |
I would guess it's a 833, looks the same style lever as in my 82 with 833.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
12-22-2013, 02:14 PM | #8 |
Is it a rare or sought after tranny? I know of a truck thats probably going to the scrapper come spring time that had a manual 3 speed with a OD gear in it. I think the truck was a '85 or so 4x4 step side short box
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208. |
12-22-2013, 04:25 PM | #9 | |
They should be sought after, as they are a great shifting little trans (perfect for light duty use instead of the M62/M64 Saginaw, and already comes from the factory with a Hurst floor shifter). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-22-2013, 04:24 PM | #10 |
Hard to say; the early A833 (RPO MY6) trans had a round shifter, although they were flat by the time I got mine.
However, that big shift boot and separate trim ring are typically for the M20 (granny gear trans). The MY6 boot tucks under the carpet/mat and does not use a separate trim ring. K
12-22-2013, 04:44 PM | #11 |
i would sell it to some mexiaricans
12-22-2013, 05:37 PM | #12 |
I have a radical idea!
That is the correct boot and shifter for '81 with the NP-833 trans. I took one out of an '81 GMC that I am going to use in my '68 C-10 that is identical top that.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
12-23-2013, 09:35 AM | #13 | |
K
12-22-2013, 06:53 PM | #14 |
Post Whore
Swap the steering wheel. Remove rear bumper. TUCK those dangling wires up under the dash. Now take the pix again. Along with the usual rocker/cab mount condition. The visor kills the look most of all. It would dang near be a neat driver w/ a mild rake-drop.
12-29-2013, 04:31 PM | #15 | |
while at it, i would get rid of the Griswold paneling too. other than that, not a bad little chevy |
12-23-2013, 02:55 AM | #16 |
I like the fake wood on it never seen that before on a pickup.Is it factory or something aftermarket?
12-23-2013, 04:12 AM | #17 |
Very cool paint job! Especially the tailgate area is interesting.
12-23-2013, 09:38 AM | #18 | |
That's probably the upfitter name in the middle of the tailgate. K
12-29-2013, 04:00 PM | #19 |
Looks like someone put a Daytona shifter in a 3 on the tree to me if you look at the column you can see where the shifter used to be
