Old 12-22-2013, 03:45 PM   #1
Carl Spangler
Carl Spangler's Avatar
How much does a fully assembled door weigh?
Greetings
I need to remove the door on my 1971 C10 and need an approximate weight of a fully assembled door. I plan on supporting the door from below and above (while removing the bolts) but will need to lift/move the door to move it to a table.
thanks
JohnG
Carl Spangler is offline   Reply With Quote
Old 12-22-2013, 04:09 PM   #2
67ctener
67ctener's Avatar
Re: How much does a fully assembled door weigh?
I would guess about 100lbs
67ctener is offline   Reply With Quote
Old 12-22-2013, 06:59 PM   #3
watash
I just pulled the drivers side door of my 71 cheyenne. I rolled the window down closed the door, took the bolts of the bottom hinge first then the top, at the pillar not the door. Ya, it ways about 100 lbs. I had to tote that thing about 75 feet, dang I am getting old.
watash is offline   Reply With Quote
Old 12-22-2013, 07:27 PM   #4
hugger6933
It is a lot lighter than the newer truck doors 99-07. I had a set of each in the paint booth the other day moving the m out and the older ones are quite a bit lighter than the new ones. I am with the above guys bout 100#
hugger6933 is offline   Reply With Quote
Old 12-23-2013, 01:27 AM   #5
Carl Spangler
Thanks all
So, a one (motivated) person move???
thanks
JohnG
Old 12-23-2013, 01:45 AM   #6
leddzepp
Moderator
leddzepp's Avatar
A floor jack will make it a lot easier
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-23-2013, 10:48 AM   #7
Lattimer
Lattimer's Avatar
I used my motorcycle jack and a block of wood under the door to make the job easy. Otherwise, its hard to get the last bolts out and not drop the door. Once its loose you can pick it up and walk with it pretty easy.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 12-24-2013, 12:48 AM   #8
twouvakind
twouvakind's Avatar
I found them unwieldy by myself, I invested in this contraption:
http://www.eastwood.com/e-z-rest-door-hanger.html
Beware of the narrow wheelbase of your jack though, ask me how I know.
twouvakind is offline   Reply With Quote
Old 12-24-2013, 11:12 AM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
5 8 ft 2X4's,one pair of sawhorse brackets,one ratchet strap.Build an A-frame and hang the ratchet strap from it.Hook the ratchet strap to the window frame.Take up the slack with the ratchet strap.Unbolt door.You can let it down with the ratchet strap or walk the sawhorse over to a table.Reverse procedure to reinstall.I used this method to replace the door hinges so I didn't need to put it on the table.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-24-2013, 12:44 PM   #10
Carl Spangler
Thanks for posting that link. I think I'll either buy this or (more likely) make something similar. Great idea!
cheers
JohnG
