12-23-2013, 06:43 AM | #1 |
67 c-10 with 12 bolt 5lug and e-brake want disc!?!?
Yes I need answers if someone would be willing to offer their knowledge ?!? I've got a 67 chevy c-10 . The front have been changed to disc and I'm looking for the way to go rear disc as well ??? What's the best way to go with parts from other trucks or cars ??? I'm also looking for the most cost effective way to do so !?!? Will someone share their knowledge with me ??? Thank you or you all in advance !!!
12-23-2013, 07:04 AM | #2 |
Re: 67 c-10 with 12 bolt 5lug and e-brake want disc!?!?
Hey boss I no some guys get caliper bracket adapters from diy4x.com and with those brackets your able to use brakes from 73-87 4x4 trucks also the brakes from 76-78 el dorado caddys, my 71 c30 is a dually and I just put a disc brake rear end from a 03 Chevy dually, I replaced the brake booster with a hydro boost, my truck came stock with front disc brakes I never changed the proportioning valve.
12-23-2013, 07:15 AM | #3 |
Ok sounds like some info I can really use !!! Thank you bud !!!
12-23-2013, 09:02 AM | #4 |
I have the same set up and would like more info also. thanks
12-23-2013, 12:46 PM | #5 |
There is a guy who sells on eBay, kit is complete save gear dope, rear end gasket and axle seals, it is offered in 5 or 6 lug versions for our trucks, and is very nice. I used the six lug kit on my 68 and had absolutely no problems, the rotors were supposed to be standard but came drilled and slotted. For less than 400 bucks this is great setup and I plan on using it again on the 70 as well.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-24-2013, 12:05 AM | #6 |
I wasn't able to find the brackets for the calibers to change my 12 bolt c-10 drums to disc !!??!! I still need to know where I can find and get the parts from ??? What car or truck parts will work to get me there !?!? My pattern is 5on 5 in front and rear !!! Already have wheels and tires !! So I really need some info from all you pro"s out there !!! What do I need to do ????
12-24-2013, 03:19 AM | #7 |
loo0k for tomsclassics on ebay. he has great prices and great quality parts i bought my rear disc rotors, brackets, and proportioning valve from him and then i bought my e brake cables, calipers and pads from CPP. and the brake hoses i bought from my local auto parts store and i used 1989 le sabre hoses for the rear.
12-25-2013, 12:45 AM | #8 |
I'm not sure but I believe, a member of this forum sells a template to make the brackets and then use the cadillac set.
12-25-2013, 01:49 AM | #9 |
Wide n'Low
Check right here on the board, CaptFab sells brackets and describes exactly what's needed .
http://67-72chevytrucks.com/vboard/s...d.php?t=398352
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
12-27-2013, 03:05 AM | #10 |
Wow you guys on here are the best !! Yes I'd have to say pro's !!! Ok yes I'm trying to be greedy !! Can anyone answer my question about get my glass back to fitting my truck ??? I've chopped it 3" and it looks awesome the side glass I THINK I've got figured out !! But the rear and windshield and let's say even the door glass as well !! What do I do there ??? Please help and I thank you guys in advance !! YOU PROS are the best thanks !!!
12-30-2013, 11:37 PM | #11 |
I saw a guy at the junkyard today collecting el dorado cadillacs disc brakes systems, What exactly years are compatibles? This guy also told me about TORONADOS also are good donors.
I would like to buy a set for the future. |
