Old 12-23-2013, 03:28 PM   #1
jrsavoie
Where can I buy an optic sensor harness and other harnesses under the intake for the
Where can I buy an optic sensor harness and other harnesses under the intake for the 1994 K3500 with 6.5 diesel engine?
I also need a Coolant temperature sensor
Any part numbers or links would be greatly appreciated
98 GMC Suburban 2500 6.5 4x4 235,000 mi, FS2500, 96 GMC 6.5 Suburban 1500 4x4 280,000 mi; Amsoil 95 Tahoe 2 door 4x4 6.5 280,000 mi; 91 international 4700 low pro, spicer 6 speed, DTA 360 with 18' van box 500,000 miles plus.1994 chev K3500 crew cab SRW 5 speed 4x4 245,000
jrsavoie is offline   Reply With Quote
Old 12-23-2013, 03:28 PM   #2
jrsavoie
Old 12-24-2013, 01:37 AM   #3
buddy_1
buddy_1's Avatar
Re: Where can I buy an optic sensor harness and other harnesses under the intake for
Here's one link http://www.ssdieselsupply.com/p62_op...r_harness.html for the optic sensor. They also have both temp sensors (gauge and ecm). Buddy
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 12-24-2013, 10:56 PM   #4
jrsavoie
Buddy,
Actually it is the engine harness that I need. The OS filter plugs into it. I wasn't sure what I needed as I hadn't investigated thoroughly enough yet.
The part number for the later harness that has a slightly longer cable due to the elimination of the filter harness is GM 15302629
Old 12-25-2013, 01:48 AM   #5
buddy_1
buddy_1's Avatar
Did a Google search and came up with http://oemcats.com/oem-parts/15302629.html & http://www.gmpartsgiant.com/parts/gm...-15302629.html .
Old 12-25-2013, 12:13 PM   #6
jrsavoie
Buddy,
Thank you much. Excellant links.
What did you put in for your google search.
I put in GM 15302629 and never came up with your results.
I did find one on dieselplace.com private for $350 shipped overnight from a private seller.
Didn't quite make it here overnight. So I shouldn't have paid the extra for overnight shipping. But I knew on Christmas, overnight was a crap shoot anyway
Buddy, Can you check this thread out, if you haven't already?
http://www.dieselplace.com/forum/63-...died-like.html
Old 12-25-2013, 12:36 PM   #7
buddy_1
buddy_1's Avatar
I put "gm part #15302629" on Google. Try it again cause I got a lot of links. I just picked a couple out quickly. Buddy
Old 12-25-2013, 12:57 PM   #8
panhandler62
Java Mechanic
panhandler62's Avatar
Here are all the harnesses NAPA has for that truck. Maybe someone else has more insight.
http://www.napaonline.com/Catalog/Re...0030%2b2030036
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 12-25-2013, 12:58 PM   #9
jrsavoie
I used to have a link that would let me do a nationwide search of dealerships for a part. I either lost it or it no longer worked and I deleted it.
Do you know of such a link?
I may have even posted it here on a thread someplace. It was quite handy. I looked for it yesterday and the day before to no avail
Old 12-25-2013, 01:09 PM   #10
jrsavoie
I discovered I was looking for the engine harness GM 15302629
I found it privately from a guy at dieselplace.com
thanks for the reply
Old 12-25-2013, 01:31 PM   #11
buddy_1
buddy_1's Avatar
I don't have one for that, I usually do that search at work. Parts department has the GM locator and I have become fairly proficient at using the catalog and the locator. I'll have to search that locator for here at the house.
Old 12-29-2013, 09:40 PM   #12
jrsavoie
I got new batteries today. I knew that wasn't the issue but they dropped blow 12 volts when cranking. They were 6 years old and Farm & Fleet had them on sale for $79.99 84 month, 850 cca. I would rather have had the Sears Diehards with 930 CCA, but couldn't justify 3X the money.
I am not getting any fuel to the injectors.
I tried to start with the Crank position sensor unhooked
I checked the pins on the cable That comes from the engine and feeds the PMD
Pin A had 1.65 to 1.75 volts while cranking
Pin E had 0 volts
Pin C had continuity to ground - .02 ohms or so
Pins B & F had no continuity
Any ideas?
