12-23-2013, 06:55 PM | #1 |
1970 c10 LSX 427 twin turbo setup
Here's my 1970 C10 Twin Turbo Setup.
12-23-2013, 07:08 PM | #2 |
Re: 1970 c10 LSX 427 twin turbo setup
More pics
12-23-2013, 07:32 PM | #3 |
KEEP ON TRUCKIN'
Beautiful setup with a great package. Welcome to the site.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
12-23-2013, 08:15 PM | #4 |
doesn't get much cooler than that!!
12-23-2013, 08:30 PM | #5 |
Dyno??
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
12-23-2013, 09:03 PM | #6 |
meowMEOWmeowMEOW
Very cool, and way different than all the custom sandrails and audio competition cars I see come out of Puerto.
12-24-2013, 02:16 PM | #7 |
12-26-2013, 02:48 PM | #8 |
where did you get the ac bracket? I'm doing a turbo build also... love the truck..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
12-26-2013, 02:50 PM | #9 |
Are you using truck exhaust manifolds?
12-26-2013, 05:21 PM | #10 |
12-26-2013, 05:24 PM | #11 |
12-26-2013, 05:35 PM | #12 |
12-26-2013, 05:44 PM | #13 |
Installing the center console.
12-26-2013, 05:51 PM | #14 |
That is awsome..... I just ordered the ac bracket.... thanks
Are you using the holley dominator efi or the hp? Or a different ecm?
12-26-2013, 05:58 PM | #15 |
i'm using Holley Dominator EFI Because i'm using to control the 4L85e Transmission ,the paddle shifter and drive by wire throtle body, with the holley HP you can not is just to control fuel and timing the engine not the transmission unless you use manual or not computer controlled transmission.
12-26-2013, 06:41 PM | #16 |
1,378 hp, man that is nice. Would like a ride in that.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
12-26-2013, 09:32 PM | #17 |
I went with the holley hp. Only reason i have a turbo 400 trans. I was going to build a 4l80e to handle 1000hp plus, but could'nt bring myself to pay that kind of money for the trans and converter... After i get her dialed in and everything else is done on my truck, i'll probably by the gears vendor od...
Was it pretty easy tuning the dominator? What size injectors are you using?
12-26-2013, 10:47 PM | #18 | |
Cheers Rob |
12-27-2013, 12:57 PM | #19 |
meowMEOWmeowMEOW
I'm not used to seeing the GV units behind the already-overdrive trannies, do you really get much use out of some of those doubled gears? (without being able to ECM/TCM control the gv unit)
12-27-2013, 05:14 PM | #20 | |
12-27-2013, 05:51 PM | #21 |
6>8 Plugless........
Very cool build and nicely done! I really like the aluminum piping and is that the intercooler on the LH fender well area?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-27-2013, 06:11 PM | #22 |
meowMEOWmeowMEOW
Damn, after looking at your build (and watching like 2 hours of Travel Channel), makes me want to go to Puerto Rico lol.
Have you used the Mastershift unit before? I read about it and another similar system, but I've never seen it used, since most of the guys with 6spd auto's will run the GM TuTd shifters. Does it allow for "full" control, or just the GV? (getting tap-shift for all 8 speeds would be epic)
12-27-2013, 07:33 PM | #23 | |
i have an another Modification in this tranny to handle the power from LSX 427 turbo. 1-Hardened Input Shaft 1-Hardened Hub. 1-TCI 2.97 First Gear Set 1-Intermediate Hardened Shaft 1-Alumum Direct clutch Assy. 1-Pump modification 1-34 elements Sprags 1-John Winter 3400 Stall 3 Clutch Lock Up Converter 1-red Alto Frictions 1-kolene friction plates with this mods the tranny hold over 1400++ with out any issues |
12-27-2013, 07:45 PM | #24 | |
Cheers Rob |
01-02-2014, 06:33 AM | #25 |
Looks like you kept the coil packs on the valve covers... Did you just custom make some plug wires andgo around the manifolds?
