12-23-2013, 08:30 PM | #1 |
Moving/flexing fuel pump
Hello all I have a 1986 Chevy c10 with a 305 motor and a mechanical fuel pump. With the engine running the fuel pump flexes/ moves in and out. Looking at it you would think the bolts are loose and its what the problem is but its not. All bolts are tight. is this normal? it looks like it has a heartbeat
Once I find the dang Gremlin that lives in my truck...Im taping him to the belt and letting the fan take care of the rest of him @ 5000 rpm |
12-23-2013, 09:19 PM | #3 |
Re: Moving/flexing fuel pump
http://www.youtube.com/watch?v=wt-K8...ature=youtu.be
Here is the link to the video the twitch can bee seen good at the 27-38 second mark.
12-24-2013, 01:39 AM | #4 |
I'm having a hard time seeing it. The truck sounds like a beast though. I don't think I would worry about it too much.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
12-24-2013, 02:20 AM | #5 |
The bolts are to long. Put 1 washer under each bolt and that should fix it.
12-24-2013, 07:26 PM | #6 |
x2 on the bolts.
I know the "VOICES" aren't real but they have some great ideas. 1978 GMC Sierra Classic C25 1983 Datsun 280ZX Turbo 1997 Chevy Cheyenne K2500 1999 Polaris Sport 400 |
12-24-2013, 07:43 PM | #7 |
Thanks.....That is most likely what it is, because it leaked oil around the 1st seal I had put on, so I put another one on and over torqued the bolts and the leak stopped but maybe the flanged area is holding it tight enough to keep the seal but the bolt heads are not flush.
Next question they were the original bolts, its a new fuel pump could it be a improperly machined pump and that 1/32" difference can cause this?
12-24-2013, 09:34 PM | #8 |
I don't think those are original fuel pump bolts. Factory bolts used a unique bolt with a smaller than usual hex head for the size of the bolt with a washer head or captured washer. Length may also have been non standard. I can't seem to find any around the shop to get measurements off of. Hopefully, someone else will. If you are OK with the head size you have, the washer trick should work. If your local auto parts store has a "hot rod" wall, I'll bet you can find some in a Mr Gasket blister pack. Chip.
12-24-2013, 09:43 PM | #9 |
I will go to my hardware store and buy some shorter grade 8 bolts with some washers...I figured they were original, but like any good ole Chevy from the mountains they might not be... Crazy thing is I have a squeal on acceleration and ruled out everything even replaced the u-joints...now I have water vapor coming out of my exhaust only under load driving or with the wheels chalked and in drive.... So now I am following other gremlins... Probably due to me not re-torquing bolts after break-in with new head, head bolts, and head gasket. But I can smoke most stock vehicles... He he...unless the squeal is my rear diff..... in that case....
