Is it possible?
Could you put a 1973-75 C10 bed on a 1968 C10 ? Wondering if its been done and is possible
A place for everything, everything in its place. Check out my build thread! http://67-72chevytrucks.com/vboard/s...43#post6129043 |
![]() Join Date: Apr 2013
Re: Is it possible?
Why do such a thing?
The body lines will not even remotely look good together. Anything is possible, but spend your time wisely and do something that will look good. The only different year beds that look good on these trucks are the 1988 and up short narrow beds. The body line match up pretty nicely, and the shape of the bed compliment the 67-72 shape. Go look at my pictures of my yellow 72 SNB in my picture album.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
Re: Is it possible?
To answer the if question I think yes it will. I know you did not ask why so I say nothing there except to answer the one asked yes I think the bolt holes will line right up. If they don't they will be so amazingly close it will be possible for a little creative slotting to make everything go.
![]() Join Date: Oct 2013
Re: Is it possible?
just remember the saying " just because you can does not mean you should"
Moderator
![]() Join Date: May 2007
Re: Is it possible?
I have seen long fleetside square body beds on 67-72 trucks before. It is possible.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: Is it possible?
Anything's possible if you have you enough time and money.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
