Old 07-17-2003, 01:18 AM   #1
steves1967
steves1967's Avatar
column shifter problems, help???
I have a 71 long bed with an automatic and the factory column shifter. The shifter doesn't want to go into park Nothing is wrong with the tranny, and if I move the linkage on the engine side of the firewall- everything works perfectly. I can't pull the shift handle back (towards driver) does something in the column need to be greased?? Thanks for any help you can offer!!!
Steve
steves1967 is offline   Reply With Quote
Old 07-17-2003, 01:20 AM   #2
70cst10_05
70cst10_05's Avatar
check to make sure all of your plug wires are out of the way, i had that happen once with mine, if i played with it for a while i could get it, but it just wouldn't go, i had a spark plug wire catchin in the linkage.
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
1972 Chevy Suburban K/10
2019 Silverado 2500 Duramax
Kevin
70cst10_05 is offline   Reply With Quote
Old 07-17-2003, 01:23 AM   #3
steves1967
steves1967's Avatar
I'll check it out, but it's been getting "sticker" over the past few weeks.
Thanks!
Old 07-17-2003, 07:22 AM   #4
JimKshortstep4x4
Smile
Sounds like your shift tube will not slide. Try lubing the bottom end of the tube where it slides and shoot some penetrant into the shift lever opening. (The tube slides up at the top also and if you direct the spray, it will usually work).
Jim
Old 07-17-2003, 08:54 AM   #5
fatfords
fatfords's Avatar
I think Jim is on the right track. Mine was acting the same way so I sprayed a load of WD-40 through the shift lever opening, until it would move smoothly. After all that finished dripping out the bottom side of the column, I sprayed some white lithium grease in the same opening and shifted throught the gears several times while spraying to get it all coated. Hasn't been a problem since...
Good Luck,
Kent
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 07-17-2003, 09:42 AM   #6
72c10step
WHYBYNU when old will do?
72c10step's Avatar
I've been having the same problem with my 72, thought it was the linkage. I'll check it out in the next couple of days and let you know.
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 07-17-2003, 04:13 PM   #7
Mixup
Mine used to hit the power brake booster. I had to cut the rod shorter.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
