12-24-2013, 04:01 PM | #1 |
Steering column swap question
Can I swap a 71 automatic shift column into a 67 with a manual shift column?
my 67 and the 71 both had power steering. its non tilt I just don't want a shifter on the floor. Last question , will I have to use the ignition on the column? thanks a bunch and happy holidays bpatrol |
12-24-2013, 04:21 PM | #2 |
Re: Steering column swap question
71 didn't have the key on the column. Not until 73. Manual shift needs manual column.
12-24-2013, 06:00 PM | #3 |
okay thanks I really didn't pay attention to it. I thought it did. I want a auto column because I am putting in a 700r4 and removing the 4 speed
thanks for the info |
12-24-2013, 09:17 PM | #4 |
Should work just fine then. Check out Shiftworks for linkage and gear indicator.
http://www.shiftworks.com/
