![]() Join Date: Dec 2012
Looks Are Deceiving 1971 C10 LWB Rebuild
Well It time to start up the rebuild. I purchased with the intent of a simple restoration but the more and more I tore it down the more I found. Oh well!
![]() Join Date: Dec 2013
Re: Looks Are Deceiving 1971 C10 LWB Rebuild
I will be listing a huge amount of parts on the parts forum next week at rock bottom prices if it helps ? let me know what you need I think I can cover just about anything !
I know the feelings I have had fender touch ups end up with total paint strippings, tune ups ending with frame off restos. Simple and quick little builds on these trucks may be a thing or the past well at least to the level I have decided upon.I have three this style 1 68, two 70's one of the 70's was gonna be the "cheaper" build of the three. It has now turned into a frame off as well with the 327 that I got with it but some engine upgrades and instead of the 3oot a T-5 from a hybrid Camaro S-10 two trans deal. I have even gone so far as to split the bedside form the inner stuctures to take care of the surface rust. things like that and it still is gonna be the "cheap"one? Oh yeah, I have a tilt column that I ground the shifter stuff off of and filled the holes primed it to paint body color to look like a factory floor shift tilt. I have a tach vac dash for it and some bucket seats with a fold down console similar to the buddy buckets but they were from a custom truck from 1993. I will have them covered to look like the seats should have from 70. and of course I will be adding power steering and brakes and disc 6 lugs still. Yeah I know what it is like when things go overboard and out of control.
I have started tackling some issues more so than others. |
New Roof Skin coming. |
OUCH ! Hope you bought it cheap ?
I'll bet that whole truck is filled with secrets and bondo ! sad when you trust someone but a shiny paint job doesn't always mean a good deal ! thats why i always buy failed projects they have little to hide !
I'd track down the seller and get my cash back
#12 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#13 |
This is where I'm at now. So far not so bad just time consuming.
#14 |
I have all new Mog suspension parts across the front, new brake calipers, brake pads, rotors, lines, McGaugay 3' drop spindles and springs and drop shocks. I've already had the upper and lower ball joints (Mog) replaced also. I will be using POR15 and a coat of chassis coat black to go on top for the frame. I want to replace the Steering gear box while torn down. are there any issues to consider for that removal and installation.
#15 |
#16 |
Rust sucks. hang in there, your roof rebuild looks good. Have fun building your truck!
All the best, Dirk and Merry Christmas. |
#17 |
I got a good day of work in on it yesterday. Im ready to start putting hr back together.
#18 |
Two coats of POR 15 followed by a top coat of Chassis Coat Black. Came out ok.
#19 |
I started putting parts back together, looks like its coming along. I'm having a hard time trying to get the lower control arm bumpers in. Any suggestions.
#20 |
Soak in boiling water until they are pliable. Also turn the upper bumpers over.
#21 |
#22 |
The rubber stop on the top of the upper control arm doesn't look right. Isn't it suppose to be on the under side?
#23 |
#24 |
After doing a 2.5 drop spindle and 3in coil in the front. I placed the wheels on and now the tie rod and lower control Arm touches the inner wheel. What gives? The spindles and springs are McGaughy's and with 15 inch Rally wheels.
#25 |
Finally got the motor in. A little at a time.
