Old 12-24-2013, 07:51 PM   #1
edgoodell@gmail.com
engine swap 350 to 454
I have a '79 Suburban that someone before me swapped the original 454 for a 350. I want to put a 454 back (as it should be) and want to put a 454 with TBI. It looks like the only major modification is to install an electric fuel pump to support the TBI. Am I missing anything in that assumption? Anybody have experience with this swap. I'm thinking I can go up through about '89 or so and pick from 2500/3500 pickups and Suburbans. We have a U Pick U Pay here in Denver that appears to be a good source at exceptionally reasonable prices. Like to hear anyones thoughts!
edgoodell@gmail.com is offline   Reply With Quote
Old 12-25-2013, 11:50 AM   #2
Zane M
Re: engine swap 350 to 454
You may also want to get the fuel tank from a TBI suburban. It will be a baffled tank and will reduce the possibility of starving the pump in the event of fuel slosh(or just always keep above 1/4 tank).
May as well grab all the wiring you need while you are at it, unless your plan was to go new aftermarket.
Zane M is offline   Reply With Quote
Old 12-25-2013, 02:43 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
TBI has a return line, doesn't it?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
