Old 12-25-2013, 08:48 PM   #1
Ridgeclimber
ECM & relay mounting location?
Where are you guys mounting the ECM and relays. I installed a LQ9 6 litre with a 4l60e trani in my 68 c10. I have a aftermarket harness. I have the ECM bolted to the left inner fender for now. But I am looking for ideas to tidy it up.
Ridgeclimber is offline   Reply With Quote
Old 12-26-2013, 07:42 AM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: ECM & relay mounting location?
This is one of the things I have to decide also on my 6.0 install.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-26-2013, 08:56 AM   #3
Indian113
Indian113's Avatar
I mounted mine I my S10 in the same place. But then I really don't have the Luxury of extra space in it.
Indian113 is offline   Reply With Quote
Old 12-26-2013, 10:10 AM   #4
ls1nova71
ls1nova71's Avatar
I fabbed a bracket and mounted mine under the front of the left fender., its a little hard to get to but its out of sight, and honestly how often do you need to take it out? There are pics in my build thread.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-26-2013, 10:57 AM   #5
JJH Jimmy
JJH Jimmy's Avatar
I mounted mine under the dash.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 12-26-2013, 02:49 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You can dig through my build to see how it currently sits, but I've had a similar setup since the beginning.
Stacks of stuff with no place to go
Layed everything along the inner fender
Its been streamlined and tucked a lot since this picture. I can't find a still shot, but it can be seen briefly in a couple of the videos on the build page.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-27-2013, 11:52 PM   #7
jorgensensc
jorgensensc's Avatar
Mounted mine behind the gauge cluster under the dash. Great for hiding, a real pain when you have to swap out the computer. Didn't thin I would need to to it that often, so didn't worry about it. Boy was I wrong!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-28-2013, 09:39 PM   #8
Daaaanz67
Here's mine tight fit between head light and inner fender. Had to work through the head light bucket and the side marker with the fender well installed to get the right angle. People don't even notice till I have to point it out usually.
Daaaanz67 is offline   Reply With Quote
Old 12-28-2013, 11:27 PM   #9
Ridgeclimber
I like the looks of your ECM mount. I just don't know if I have enough length in the harness to reach.
Old 12-30-2013, 10:35 AM   #10
Billett
Billett's Avatar
Zip tied to the battery haha. Not pretty but it gets the job done until I can make a nice mount up.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
