12-25-2013, 10:47 PM | #1 |
1984-85 rear axle in 1968 Pick up
I might be able to buy a junk 1984-85 chevy with 5 lug axles. Will they fit my 68 stepside with a 307 and 3 on the tree?
Thanks-Mika |
12-26-2013, 12:21 AM | #2 |
Re: 1984-85 rear axle in 1968 Pick up
does your truck have leaf spring rear suspension ?
I believe they are a little wider than yours also
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-26-2013, 12:22 AM | #3 |
68 axles are narrower than 84-85
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
12-26-2013, 12:29 AM | #4 |
Truck junkie
I just did this entire swap in my 67. The axle housing is 1.5" wider than the 67-68 axle housing so the axles themselves wont fit in the 68 housing. My truck was trailing arm so I had to cut all the pads and brackets off of the 80's axle housing and make pads to weld on for the trailing arms and I had to relocate the track bar but it fit nicely and was a better ratio than the posi I removed. I need to rebuild the posi and replace the axles the previous owner attempted to redrill. For about 260.00 plus tax I could have bought 5 lug conversion axles from summit but the posi unit Needs clutches and the 4:10 ratio was bad with the th350 in the truck. I will rebuild it and use it in a different project.
12-26-2013, 08:25 PM | #5 |
I did the same as OLDTRUCKFANATIC BUT with a 3.42 of a suburban 90s and I had to buy the brackets that hold the trailing arms at classic performance CPP, they cost about $50.
Also I had to modify the manual brake cable. |
12-26-2013, 09:52 PM | #6 |
Several companies make a kit to put that axle in your truck I think they are normally less than $150 maybe much less. Your ratio choices would be a bunch greater if you did do that and consider that swap, it has been done many many times.
12-27-2013, 02:48 AM | #7 |
Right: I just took a look on the classic performance products catalogue and yes the kits start on $129 and works with 73-87 rear ends. they use to sell only the trailing arm axle seats that's why only paid about $50
