12-26-2013, 03:25 AM | #1 |
New weatherstripping
Hi. Santa brought me some new parts for my truck this Christmas. One of which was a new set of door weatherstripping. I was wondering if I needed to do anything special to get them to stay on? Do I need to glue them in, or will they just stay in place? I've also heard that some people heat them up to help the rubber shrink to fit. Any suggestions would be appreciated.
White70C20 1970 Blue C20 - 250, 4 speed 1985 Ford Thunderbird 2005 Pontiac G6 |
12-26-2013, 10:06 AM | #2 |
Re: New weatherstripping
most of the weatherstripping needs too be glued in. 3m makes weatherstripping glues thats available at dang near any auto parts store its good stuff. it can get a lil' messy though.
when i did it i used some tape and a bunch of these paper clips(the ones i used were slighty bigger than this one) as clamps and they worked awesome although any spring clamps should work. do yourself a favor and preinstall them with tape and test'm. alot of guys have problems with haveing too slam their doors after installing.most times after one hot summer they "break in"and work a lil' better. i've learned here on the board that if you trim the butted ends at a 45 degree angle that you wont trap air in the seal and makes it better when closing. i've also learned from expeirence that if your seal is a lil' weak at points you can put a small slice and slide some vacuum hose into the seal too stiffen it up a lil'. i had to do this on a hatchback once too keep it from leaking. just remember too test fit first. oh an gettin the old glue off can be a pain.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
12-26-2013, 10:20 AM | #3 |
I will second the tape and heavy paper clips, they work very well. I would advise getting the black 3m weather strip adhesive , as it hides a bit better than the yellow. Clean area very well with alcohol wipe to better let the glue and rubber stick. Follow the directions and don't rush the glue has a flash time that works better than trying to rush it.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-26-2013, 11:04 AM | #4 |
The Older Generation
All the above is true.... unless she bought the press-on weather stripping. If so, all you have to do is slip it on the pinch weld, trim it for length, and you're done. LockDoc
12-26-2013, 11:24 AM | #5 |
thanks doc i forgot too mention them....btw happy b-day
12-26-2013, 11:36 AM | #6 |
Thanks...
LockDoc
12-29-2013, 01:46 AM | #7 |
Thanks guys,
The weather-stripping is from LMC. It's the kit they sell. I'm back home in Iowa for the holidays and my truck is back in Kansas, otherwise I would probably have it done by now. I hope it doesn't cause me too much trouble. Also, I'll have to do this outside. Will the adhesive stick if I do this in Kansas winter temperatures (20s-40s)? If not, I might have to tough it out until spring.
12-29-2013, 10:39 AM | #8 |
A trick I learned at a Chrysler dealership years back... Once it's installed and glue has set overnight, use silicone spray on the new weatherstrip, close the door and leave overnight. The rubber softens while absorbing it and holds the shape when dry. We used to reshape flattened weatherstrip with clamps this way. (Wind leaks around doors).... And reduces slamming of your door which is common for a while with new rubbers. I use that stuff on everything now, from CV boots to brake hoses since I've seen that trick.
