Wrench Wench
![]() Join Date: Apr 2008
Found some Borg/Warner OD parts
Found shop that sells parts for the Borg - Warner overdrive units....Solenoid, seal, cable, kickdown, relay etc. A little pricey, but also very hard to find.
http://www.fifthaveinternetgarage.com They sell quite a few hard to find parts for older vehicles.
If everyone had good taste, who would buy all the FORDS? ![]() Women join us!! BUSTED KNUCKLE BABES ![]() "Face it girls, I'm older and have better insurance" -Fried green tomatoes |
![]() Join Date: Jun 2013
Re: Found some Borg/Warner OD parts
Just checked out the Web site. Thank you so much for the link. I've been looking for over drive parts and info for some time
Have a great New a Year |
Wrench Wench
Here are some good info and guides I used when installing mine. They are well worth the effort!! Happy New Year!
http://speedprint.com/deves50/overdriveindex.php
This is great info thank you again just what I have been looking for hopefully will be installing my OD and my new rebuilt motor in about a week or so this info is priceless
Happy New Years to you too |
Hope to get mine hooked up one of these days. I did luck out & find the parts I needed to hook the overdrive up. Mine has the sync trans from a '66 from what I've gathered online. Great info
Wrench Wench
I used a little different wiring on mine, Having HEI and not wanting to install an under pedal kickdown I ended up using a toggle switch mounted on the dash for my kickdown.
Can we have the bosch part number for the relay. ? I just hung a 30 amp push pull switch on the gear sift but it will probably burn up someday. been ok for a few months thu?
Wrench Wench
Bosch #0332209150 + socket with pigtails....... They are now Tyco, but I would look for original as mine has been trouble free for over a year now.
