Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 12-26-2013, 11:03 PM   #1
jaredg
87 Chevy B-60 Bus
Hi All,
I am taking on a rather strange restoration/conversion project. I had found my old bus from childhood a few years back. Its a 1987 Chevy B-60 Wayne 54pass with a 366 Holley 4bl/Allison AT545 trans. I just recently completed a nice 30x50 pole building to house my project in. The first thing I am investigating is perhaps an upgrade in power train. I want to take this thing on road trips and currently the 366 is frying its brains out trying to go 50 on the highway. I assume the 6.83 rear end isnt helping any. I also suspect the 366 is a little worn out and so I want to consider either a new 366 engine or perhaps a 427 and of course get lower rear gears.
If I am going to get a new engine would it be worth it to bump up to a 427? Perhaps Fuel Injected? Would there be any noticeable power advantage?
I have tons of other questions and will post pics of the build in due time.
Thanks so much for reading.
Jared
jaredg is offline   Reply With Quote
Old 12-28-2013, 05:26 AM   #2
mrolds88
Re: 87 Chevy B-60 Bus
427 will work. Or even a 454 out of a pickup would be fine too. Get a late enough model to get the TBI and take everything that you need for the conversion. Also ditch the 545. if you want to keep an automatic, go for a Allison 2000 or 2400. The 545's were good transmissions, but they dont lock the converter and they keep the rpms up. Actually I just had a thought. Every once in a while you can run across a fleet truck for sale (schwans and ryder comes to mind) that you might be able to do a whole drivetrain swap from. Engine, trans, rear. Plus sell off extra stuff from what you dont want.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-28-2013, 10:19 AM   #3
63 & 64 Bowties
and a few others
First off, welcome to the forum!
What about a used/wrecked newer school bus as a donor for engine/drivetrain and switching to diesel? Look on either PublicSurplus.com or GovDeals.com
Oh, and....
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 12-28-2013, 10:36 AM   #4
jaredg
Thank you so much for your responses!! Those are great ideas! I am definitely going to investigate these options. This forum is so full of great builds - heading back over to that awesome C-50 pickup build with like 30 pages. Cant get enough of this stuff.
And here is my pride and joy:
Inside her new home:
Old 12-28-2013, 11:47 AM   #5
63 & 64 Bowties
and a few others
Wow, that's clean.
Another option of a donor school bus, maybe you can get rid if the Dayton wheels and swap over to some nice Budds.
Old 12-28-2013, 12:34 PM   #6
jaredg
Originally Posted by 63 & 64 Bowties View Post
Wow, that's clean.
Oh you read my mind. I'd love a set of Alcoa Aluminums on this and I hear its a huge undergoing to try and swap the hubs of the Daytons - might as well just get donor axles.
Old 01-06-2014, 05:46 PM   #7
jaredg
I've been working on some exterior renderings of possibly what I'd like this thing to be. I want to keep the thing looking like a school bus but upon closer inspection a unique bad ass mild RV conversion:
Old 01-06-2014, 05:58 PM   #8
MalibuSSwagon
I remember those from my youth as well. I remember the ones I would ride on were manual trans, I'm guessing my rural school district saved some cash by opting for the manual.
MalibuSSwagon is offline   Reply With Quote
Old 01-17-2014, 10:09 PM   #9
jaredg
I found this low mileage 1988 427 engine on the bay. What do you all think? 2 main questions - can I convert this to fuel injection? And, IF this is a NON air brake engine would I be able to add my compressor to it? I posted the question to the seller whether this is an air brake engine or not but havent heard back yet.
http://www.ebay.com/itm/ENG-7-0L-427...item51b7187503
Old 01-17-2014, 11:30 PM   #10
mrolds88
Converting to injection SHOULDN'T be too bad. Trick is to get a setup off of a late 80's very early 90's 454. They used an adapter setup on a quadrajet type intake. Bolt pattern is same a Qjet. Then obviously get all sensors and wiring and computer.
93 K2500 xcab 6.5TD
Old 01-18-2014, 12:02 PM   #11
jaredg
I have another option: A friend of mine half way across the country has a mint condition 1990 Blue Bird GMC bus with a newer 8.2L Detroit (bus was originally a gas), Allison MT643 transmission (has the lockup converter unlike my AT545), air brakes like mine, budd wheels, an electric retarder ( I have no idea what that is) and goes 65 mph at a decent RPM. Bus is rust free.
So in other words:
Axles are a plus - I would gain the budd wheel setup and better rear end ratio
Transmission is a plus - I would gain the lockup converter
Engine - unsure if the 8.2 is a plus as I've heard some bad things about this engine online.
The wheelbase is the same as mine - I'm thinking it might be easier just swapping the bodies
He is asking $4000 - I'm sure I could get him down a little
What are your thoughts?
Old 01-24-2014, 02:56 PM   #12
jaredg
Sorry to be a pest -but here is my update:
I think I am going to walk away from that offer with the 8.2 diesel - too many horror stories with that engine that I've read.
I found a 1995 GMC topkick with a fuel injected 427 in it with only 72K miles. I think I am going to pull this engine for my swap. My main question is this - knowing that my 1987 bus is a 366 carberated engine - what kind of electronics should I be looking for off the 95 Fuel Injected 427 to take from the swap?
Here is one shot of the engine :
Old 01-24-2014, 05:44 PM   #13
jaredg
Here is a few more of the FI 427 with some close ups of the wiring going into the firewall:
Old 06-11-2014, 08:20 PM   #14
jaredg
After a long three months, I finally got a late 80's 427 tall deck rebuilt and installed into the bus. Today i finally got her on the road and she drives really well. To those who think there isnt much power difference between the 366 and the 427, there surely is. I have a very steep hill near my house that the 366 used to crawl at 10mph, today the 427 held at 40mph. I'm sure it also has to do with a much better carb than the old governed holley too.
My real dilemma now is that the thing sounds like its screaming at 55 mph and I believe I have a 6.85 rear end which would be the culprit. Keeping my eye out for rear end more suitable. I have a tach that I am gonna install to see where I'm at when approaching 55 in the meantime.
Here are some pics from the build:
Old 06-15-2014, 12:56 AM   #15
Softpatch
Softpatch's Avatar
Hi new to this HH and like the BBC let me spit ball what if you got a OD like a Gearvendor.?
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 06-16-2014, 08:08 PM   #16
_Ogre
_Ogre's Avatar
or get the 2 speed rearend out of softpatch's viking
i bought a 56 48 pass rv conversion school bus with a 2 speed rearend out of colorado in the 70s
it'd climb mountains at 60 and do flat land hauling at 80
shop air compressor timer
Old 06-18-2014, 10:26 PM   #17
Biscayne Stocker
Ive got a 6 Speed Allison 1000 I might be interested in getting rid of. Let me know.
Scott
Biscayne Stocker is offline   Reply With Quote
Old 06-22-2014, 08:49 PM   #18
jaredg
ok so I just installed a factory GM tachometer. I took her out and achieved 55 mph at 3200 rpms. If I go 60 I assume it will be around 3600 or so. Would that be pushing the engine too much? Anyone know what a safe RPM would be to stay under with one of these 427's?
Thanks.
Old 06-23-2014, 07:59 AM   #19
C10 - C90 Bill
C10 - C90 Bill's Avatar
A 2-Speed Rear will not get you anymore on the top end. Your last gear on your trans and Hi on the rear will still be the same. A 2-Speed Rear actually only "splits" the gears that you already have.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
