Old 12-26-2013, 11:20 PM   #1
mgchevyparts
mgchevyparts's Avatar
pros/cons of shock extenders
Installing flip kit, what are the pros/cons of using shock extenders. The way I see the extenders keep you from having to buy new shocks, any down side to this other then maybe just looks?
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 12-27-2013, 10:46 AM   #2
Jonboy
Slots go on anything!
Re: pros/cons of shock extenders
They do hang down some, but that is a minor annoyance to me. I have used them on the couple trucks that I have had that are lowered.
1974 Jimmy- 5.3/4L80e/NP241
Old 12-28-2013, 12:49 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
The "pros"are they allow your shock to function properly. The "cons" are you will hate your ride if you dont.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-28-2013, 12:50 AM   #4
KrazyRay
KrazyRay's Avatar
Shock extenders are a must with the axle flip.
KrazyRay is offline   Reply With Quote
Old 12-28-2013, 12:51 AM   #5
mgchevyparts
I probably didn't word it right. You can get shorter shocks and not use the extenders so I was wondering if either method is better then the other and why.
Old 12-28-2013, 12:53 AM   #6
mgchevyparts
I was removing the bump stop brackets, I hate removing factory rivets
So I decided to try my 120v Hobart plasma cutter, worked like a charm. Took about 15-20mins to blow the heads off then pry the bracket loose. Just don't use this method if you want to save the bracket.
Old 12-28-2013, 01:31 AM   #7
joe231
joe231's Avatar
stock front shocks will fit after flipping the axle, on the pick ups anyway....
not sure on the blazers and burbs.
CHEVY ONLY
Old 12-28-2013, 11:11 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes you can use shorter shocks, but your ride will be better with long shocks and extenders.
Articles-
"Refining Sierra"
