![]() Join Date: Jul 2013
Steering column. & pedal assembly
Need recommendation for source of non tilt floor shift column.
Also converting to auto trans. Need source for pedal assembly. Thanks in advance! |
![]() Join Date: Aug 2008
Re: Steering column. & pedal assembly
Didier makes some great quality products. Be wary of cheap imitation. Do some research on the cheaper brands. There is a thread somewhere on here regarding the poor quality of some Chinese brands. In a nutshell they have inferior design and welding that could fail. As for the pedal assembly, you already have it! Just disassemble the existing manual pedal assembly and remove the clutch pedal!
Thanks for the info. You confirmed my thought on pedal assembly!
Did u mean Ididt?
Nice! Thank you and happy new year! Are u sure the gift is your wife's?
![]() Join Date: Mar 2011
I would check the classifieds here first. On the brake pedal assy, I would definitely use an original used assy. NEVER trust your life on chinese products!!!!
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
![]() Join Date: Jul 2012
I have done the column auto shift to floor shift (auto trans) swap. Spent many hours of research before making a decision. Bought a used column (non-tilt) off of a board member from the classified section. Needed a new bearing and turn signal switch but other than that it worked well. Had a tough time in the reassembly so take pics of the disassembly process if you go that route.
Ididit and Flaming River have the best member reviews (be careful of knockoffs as stated above by WIDESIDE72, there is some excellent reading provided in this forum on "other" brands). I will probably go this route for a tilt option in a few years. |
