Old 12-27-2013, 08:55 PM   #1
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Rear disk conversions
All,
Looking for some advice, I have done two conversions and really not satisfied with either.
I am about to change the prop valve out on my truck to an adjustable one because I think the rear brakes are not where they should be. My question is, should the rear lines also be changed out to smaller diameter lines or will the adjustable prop valve take care of that?
Brakes have been bled to death, no air, no leaks. Have the Camaro kit on one truck and a CPP kit on the other. Everything is new on both systems from lines to calipers.
Thanks,
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 12-28-2013, 12:26 AM   #2
oldman3
oldman3's Avatar
Re: Rear disk conversions
You say your not satisfied, what's the problem?? Not stopping good, rear locking up before front, need to know...Jim
oldman3 is offline   Reply With Quote
Old 12-28-2013, 12:58 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
on disc / disc the lines should all be the same diameter.
dwcsr is offline   Reply With Quote
Old 12-28-2013, 03:47 AM   #4
andrewmp6
Did you replace the master cylinder for one set up for 4 wheel disc?
andrewmp6 is offline   Reply With Quote
Old 12-28-2013, 08:39 AM   #5
woodwright
Enjoying left field
woodwright's Avatar
The guy from SSBS told me that a MC and distribution block/prop valve from a 4 wheel drum truck will work but you might need to add an adjustable prop valve to the rear.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 12-31-2013, 08:04 PM   #6
NEWFISHER
NEWFISHER's Avatar
I used disc /disc master, no prop valve, smaller lines to the rear and a 2lb. residual valve at the connection at passenger frame rail for the rear most hard line. Works GREAT!
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 01-02-2014, 08:16 PM   #7
71meangreenc10
Jim,
It stops, just doesn't feel right, the Camaro calipers feel a lot better than the CCP kit.
This was what I was thinking.....Probably will re-do all the lines to match.
Everything replaced to meet disk/disk setup.
Interesting.
This could be an option. What did you put on the front lines?
Thanks for your replies guys.
Smitty
71 C30 Wrecker
