![]() Join Date: Mar 2005
Glove Box Door - AC Vent Hose
I'm getting a lot done on my truck this last couple of weeks, Finally! Today I put the glove box together and am running into a clearance issue with the right side AC vent hose and the arm for the door. Any suggestions?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
Old member
It's got a liner that is made for trucks with AC. If it's not the AC glove box liner it want work without some mods. What are the problems?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Glove Box Door - AC Vent Hose
As you close the door the arm attached to the door hits the ac vent hose
Old member
Is the arm bent to much. The AC hose should turn left and go over to the outlet. Its a pretty tight bend.
![]() Join Date: Sep 2012
subscribed, about to do this myself
