Old 12-28-2013, 03:12 PM   #1
adricar1
pulling engine
i have the front off my 1971 k1500, and want to remove the engine transmission th350 and transfer box? i have a new 383 and want to freshen up the auto .
what the easiest way ,will it all come out the front of the truck , or is it best to split the engine and transmission and remove the transmission from below the truck?
thank you
Adrian.
adricar1 is offline   Reply With Quote
Old 12-28-2013, 03:35 PM   #2
zeldman
zeldman's Avatar
Re: pulling engine
Depends. If you have a lift, it might be better to split and come out from the top and bottom. If you have a good hoist or overhead chain lift, and the front clip is already off, then I would think it would all come out the top.
Oooops.. just noticed the K. If there is room I would still think that since the front clip is off that taking all out together would be easiest. I am just not sure if the transfer case will clear everything.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 12-29-2013, 02:01 AM   #3
Z10
Z10's Avatar
Re: pulling engine
You can take the engine and trans out as a unit with either a hoist or engine crane, but you'll also need a load leveler to tilt the engine as it comes out.
Here's an example.
http://www.denlorstools.com/home/dt1...eveler&x=0&y=0
Click on the link in my signature below and you'll see a couple of pics of my engine being pulled with this.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 12-29-2013, 04:23 AM   #4
adricar1
Re: pulling engine
hi guys , yes i have all the equipment ,hoists chain block etc but will the transfer box come out with the engine. is there enough room?
