12-28-2013, 04:34 PM | #1 |
rad support carriage bolts
What was the purpose of using the 2 carriage bolts versus regular bolts? Having fun trying to remove them by myself with channel locks and my ratchet wrench -_- ...and can u get the bushing kit from parts stores or is it an order only item? Thanks
12-28-2013, 06:17 PM | #2 |
Re: rad support carriage bolts
Bushings order only not at local parts stores. Carriage works fine if you can keep it in square washer. 40 years usually messes that up.most tomes I just cut bolt.
12-28-2013, 10:35 PM | #3 |
Imo the factory originally used carriage bolts for easier/ quicker assembly. The carriage head would not require a wrench to tighten it all up. They werent concerned with you and i getting it apart 40 yrs later. I usually use the hot wrench and replace the bolts and bushin as a whole.
12-29-2013, 02:38 PM | #4 |
Lol you are right. Im just having a hard time getting the nuts off due to the tops spinning -_- any suggestions on best place (and price) for ordering a new rad support mount kit?
12-30-2013, 02:07 PM | #5 |
I usually tack weld the carriage bolt head to the square washer and it comes off or breaks
39 GMC pickup,70 GMC K1500 short bed 4x4 ,72 K10 short bed step side 4x4 ,71 short bed fleet side , 72 K20 long bed ,74 K10 long bed , 69 C30 dump bed dually, 79 K30 standard cab dually , 02 Dodge 4x4 dually |
02-17-2015, 09:41 PM | #6 |
If someone were to replace those bolts with carriage bolts, what size are they please?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
02-17-2015, 10:00 PM | #7 |
To remove mine I was going to try and grab the shank of the bolt with needle nose vice grips, pray and loosen the nut.
Think it will work??
02-17-2015, 10:21 PM | #8 | |||
The Older Generation
Probably not, but good luck with it..... LockDoc
