Old 12-28-2013, 04:45 PM   #1
msgross
msgross's Avatar
Sagging door on your 88-98 chevy? Don't buy the auto zone parts
Stay away from the Help parts #38416. I replaced my drivers door in Nov and the lower already failed. The bushings are too brittle and the next one crumbled on installation.
GM has the OEM bushings #16632192 and 93 for $3 each. They also have the pins if you think that you need them. 2 man job that takes an hour if you take your time. Much better now. Found a decent DIY on you tube, best tip is to use a bolt and washer to press the new bushings 3/4 in and then tap them home. Used two jack stands with rags on top to hold the door, wifey balanced it.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-31-2013, 09:52 AM   #2
400sbctruck
Re: Sagging door on your 88-98 chevy? Don't buy the auto zone parts
Most of the dorman "help" offerings are junk. But stocked because they are low-turnover items, and variety of solutions can be stocked cheaply. Sad, Chinese truth!
400sbctruck is offline   Reply With Quote
