Old 12-28-2013, 05:50 PM   #1
Chevy_422
65 Chevy fleetside need help!
Hello everyone
I need some help with a frame swap
I found a 65 fleetside LWB but I want a SWB truck and I know where a 69 SWB frame is at. My question is will the 65 cab and front clip bolt onto the 69 frame?
Basically what I'm getting at is the frame the same in between those years??
And if this won't work and I wanted it to be SWB any ideas on how to do so??
Chevy_422 is offline   Reply With Quote
Old 12-28-2013, 08:40 PM   #2
Grandpa54
Grandpa54's Avatar
Re: 65 Chevy fleetside need help!
I think up to 72 will fit
Grandpa54 is offline   Reply With Quote
Old 12-29-2013, 12:56 AM   #3
Captainfab
60-66 Nut
They are basically the same but there are a few differences. The frame horns are different, the radiator crossmember is not there, the radiator support mounts need to be moved, the rear cab mount brackets need moved, and I think that is it.
Before you go to all this work, make sure you know what the laws are in your state or county regarding a vehicle with different VIN's on the frame and body.
If it were my truck and I did not have the means to perform the work myself, I would check into what it would cost to have your original frame shortened. Compare that to what you will have to pay for the '69 frame plus the modifications necessary to mount your body and bumper.
