Old 12-28-2013, 10:02 PM   #1
dmartin1
dmartin1's Avatar
steel wheels from the 80's?
are white steel factory wheels( on a 3/4 ton) like early 80's the same as the steel factory white wheels from 67-72 trucks?
reason i ask is, ihave a 72 that needs wheels, and i can get these for 60$ for all 4 wheels.
i know lug pattern etc is fine, but will the hub/center caps from 67-72 fit on these wheels?
it has some 70's-80's gmc caps on it that are fairly decent size.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 12-28-2013, 11:08 PM   #2
Lattimer
Lattimer's Avatar
Re: steel wheels from the 80's?
Pretty certain the steelies are the same all the way up to 1988 at least. 3/4 ton caps from our trucks should fit any of those wheels.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 12-28-2013, 11:43 PM   #3
Sicklajoie
The Niner
Sicklajoie's Avatar
Up to 1987 should work just fine with any 12" hubcap.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 12-29-2013, 01:58 AM   #4
White70C20
White70C20's Avatar
Actually, 8 lug rims from a 2013 2500 will fit our trucks. It's pretty cool that they never changed the lug spacing or hub diameter. If I had the money, I'd love to put a set of brand new OEM aluminum rims on my green '70. I think it would look pretty cool.
White70C20
1970 Blue C20 - 250, 4 speed
1985 Ford Thunderbird
2005 Pontiac G6
White70C20 is offline   Reply With Quote
