12-28-2013, 11:01 PM | #1 |
1970 1 ton waddyathink
A friend of mine has this old '70 1 ton, I need it like I need another hole in my head.
It's Data plate lists it as a 157" wheel base, 4DG5AD west coast mirrors 4F51AF front/rear shocks 4F60AF heavy duty front springs 4J70DS brake booster equip 4M49AC turbo hydra-matic 4T60AA HD battery 4Z52AA full foam seat 4612AC green vinyl 9668AA 3 speed auto trans 9920CA flasher unit 1681BA special paint 4F19AD body cross sill mtn 4F59AC front stabilizer 4G60AH aux springs 4LS98A 350 cu. in. V-8 4R05LD dr wheel conversion 9638AB permanent anti free 9719AA fuel tank cylinderic It appears to be somewhat rust free, no apparent rust in the typical areas. The truck had cargo box on it that was just removed. And it has a production looking frame bracket that the box was setting on. If anything it might be a fixerupper and sell it. Sorry for the bad pictures, I need to get software to manage my GoPro video. I had to stop the video and take a picture of the screen to show the truck. I should have stopped and changed to picture mode.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
12-28-2013, 11:34 PM | #2 |
Re: 1970 1 ton waddyathink
I think you need it
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
12-28-2013, 11:38 PM | #3 |
I think I need it!!!
Wade |
12-29-2013, 11:57 AM | #4 |
It's a former Nationwide Car Rental (EZ Haul) truck
http://i20.photobucket.com/albums/b2...55/2ace_12.jpg
12-29-2013, 01:23 PM | #5 | |
Well the color is for sure very close to it.
Thanks for the info. Quote:
12-29-2013, 04:22 PM | #6 |
I'd bet money on it. They even had those 2 hole Budd wheels and that's the only place I've seen them. I wonder what that second 3spd auto trans option is. The M49 already covered the Turbo Hydramatic
12-29-2013, 05:14 PM | #7 |
I almost posted something about that in the initial post, but just figured maybe a goof up.
And maybe one of you guys might have insight to it. I haven't really spent the time decoding the build tags. I wonder what the 9719AA fuel tank cylindric amounts to. It does have this large 20 gallon saddle tank on the passenger side frame rail but I didn't notice a fuel switch valve in the drivers floor beside the seat. I've made them an offer, (not very much) it is complete, less a carb. I figure the engine is worn out. If I get it I'll clean it up and put a carb on it, a battery and see what happens. I might keep it and build a flat bed for it later on, like I need another one. These old ton-ers are just cool. It does seme to be somewhat solid and minimal visible rust.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy Last edited by tlcrz1972; 12-29-2013 at 07:06 PM. |
12-29-2013, 09:58 PM | #8 | |
that may have been SEO for special equipment option, my memory is hazy also, if that frame mounted tank is cylindric, odds are that it's factory installed. follow the lines and there will be a switch in the dash, or a manual valve under the dash
JK Last edited by jkeating1; 12-29-2013 at 10:07 PM. Reason: add info |
12-29-2013, 10:05 PM | #9 |
I think it would be really neat to have a thread that lists all of the '67-'72 options with numbers and descriptions, for light duty and medium duty trucks.
12-29-2013, 11:29 PM | #10 | |
