Old 12-29-2013, 12:12 AM   #1
jmlloar
jmlloar's Avatar
Fuel guage problem
91 Topkick
having problems with the fuel gauge not working.
Gauge is at full.
cant seem to remember if that means it is shorted to ground or broken wire.
Seem to remember it being shorted to ground was buried above full and broken wire was below empty.
Doesn't make sense to me for it to be exactly on full mark with the sending unit unhooked.
Anyone have some input? And/or a wire diagram for it?
jmlloar is offline   Reply With Quote
Old 12-29-2013, 10:20 AM   #2
Re: Fuel guage problem
That should be a short to ground.
Old 12-29-2013, 11:24 AM   #3
jmlloar
jmlloar's Avatar
I was thinking short was towards full, but I always thought a short pushed it way past full. And this one is dead on the full mark. Never seen this problem on newer body style, all of my experience is with 87 back pickups.
Old 12-29-2013, 11:30 AM   #4
ChevyTech
If the wire to the fuel sending unit is unplugged, the fuel gauge should read over the full mark.
Old 12-29-2013, 04:09 PM   #5
jmlloar
jmlloar's Avatar
So then a corroded wire makes more sense, found many of these on headlight harness and some of the combination switch wires. Truck was a NJ plow truck and salt spreader so it has seen above average winter use.
Old 12-29-2013, 11:26 PM   #6
ChevyTech
We used to have suburbans come in where the baffle would come lose inside the tank and hold the float up. They would be towed in, out of gas, but the owners thought they had fuel in the tank.
Salt and other chemicals are used here too. So much is on the road in areas now that it leaves a cloud of dust behind vehicles from the pulverized salt on the road. The roads aren’t white with snow, they are white with salt. We are double digits sub zero now, and the salt does not melt anything when it is this cold.
Old 12-30-2013, 12:08 AM   #7
jmlloar
jmlloar's Avatar
As of now the gauge doesn't move. Sending unit is unhooked and stays the same unhooked or shorted to ground, So it looks like I'm looking for a broken wire or terminal instead of a shorted wire. Already tested at the weather pck connector at battery box and no change. Only other connector I can find is inside of cab on the firewall. That's where a wire diagram would be great. Wire harness is nothing like the pickups harness. I have a few extras to add I pulled from a pickup and there is no where to hook them up on the med duty harness.
Old 12-30-2013, 10:34 AM   #8
ChevyTech
I would do some testing right at the gauge.
Old 12-30-2013, 12:57 PM   #9
54 jimmy
54 jimmy's Avatar
I have a complete cluster you could have if you want. just cover shipping. it was out of an 89 k1500. if this helps you.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 12-30-2013, 06:40 PM   #10
jmlloar
jmlloar's Avatar
Offer is appreciated, but mine is a Topkick and uses a completely different cluster. It has needle type gauges and air brakes.
Old 12-30-2013, 07:22 PM   #11
burkey05
burkey05's Avatar
you might have to invest in a repair manual
something like this off ebay(i know yours is diesel tho)
http://www.ebay.com/itm/1992-Chevrol...d71a78&vxp=mtr
actually this one is prob better
http://www.ebay.com/itm/1991-GMC-Top...2216ff&vxp=mtr
this one actually has a diesel supplement, but its a 90
http://www.ebay.com/itm/1990-GMC-Top...27b7cb&vxp=mtr
1988 GMC c1500 SWB D/D RHD 5.7L 700R4
burkey05 is offline   Reply With Quote
Old 12-30-2013, 08:01 PM   #12
jmlloar
jmlloar's Avatar
Watching the middle one, but don't have the extra $40 right now.
Old 12-30-2013, 11:55 PM   #13
54 jimmy
54 jimmy's Avatar
well I tried. good luck tracking the problem down.
Old 12-31-2013, 09:42 AM   #14
400sbctruck
If the needle isnt "past full" its also possible the float in the tank is hung/stuck. A rubber mallet and a half a tank or less "may" fix that, allowing it to settle.
The float arms can also pinch on the pump hanger, causing same problem.
As u check to see if the connections are good, take a mallet /w/ you.
Also could be "pig tail"
400sbctruck is offline   Reply With Quote
Old 12-31-2013, 10:20 AM   #15
dragginmetal
here, just not logged in
dragginmetal's Avatar
Is a Topkick a 4500? I have most wire/d up to the 3500s. There haynes style but if any will help ill post what you want.
dragginmetal is offline   Reply With Quote
Old 12-31-2013, 08:07 PM   #16
jmlloar
jmlloar's Avatar
See previous posts, Sending unit is not connected to harness. Testing at the wire and at the connector from the main harness and no change.
Old 12-31-2013, 08:10 PM   #17
jmlloar
jmlloar's Avatar
The topkick starts at 4500. Mine is a 7000. Pretty much everything is slightly different than both the 1500-3500 and 3500HD trucks. The wire harness only shares stuff like the turn signal switch and headlight switch. Main harness is completely different.
