12-29-2013, 11:57 AM | #1 |
49 door glass
Trying to decide if I should go with the 1 piece door glass, or rebuild the vent windows and put new orginal glass in. Looks like I can do the 1 piece a lot cheaper
12-29-2013, 12:12 PM | #2 |
Re: 49 door glass
'49 had 1 piece door glass. Vent/wing windows started in '51. Good luck which ever you decide
12-29-2013, 01:45 PM | #3 |
Re: 49 door glass
Ok thanks this is all new to me. They must of put 51 doors on this truck
12-31-2013, 10:44 AM | #4 |
Re: 49 door glass
Does it have swing handle or push button? The striker is different as is the cab where the striker bolts. They will "work" when swapped but not as good as with the proper striker to latch combination. They even made an "adapter" in 51 because some doors were swing handle and some were push button.
The one on the left is a swing handle, the middle one is the "adapter" and the one on the right is the push button handle striker. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
12-31-2013, 11:49 AM | #5 |
Re: 49 door glass
It has push button handles and has the "adapter" striker on it. Next question can I put 1 piece windows in it with out the vent? Thanks for your help
12-31-2013, 11:52 AM | #6 |
Re: 49 door glass
I don't know what you need to do it, I have looked at them but never did one. I do know I dig the early look with the metal frame around the glass.
Brian
12-31-2013, 12:18 PM | #7 |
Re: 49 door glass
I just talked to a parts dealer looks to be a lot of work to do that. might go ahead and rebuild the vent windows
12-31-2013, 12:18 PM | #8 |
Re: 49 door glass
It can be done. You will need the proper run for the channel in front plus the frame for the glass and I am thinking that the regulator is different.
From going back and looking at this thread http://67-72chevytrucks.com/vboard/s...d.php?t=607302 and the side photo of your truck I'd say that it is actually a 52 or 53 truck rather than a 49 or they used a 52/53 cab and a 49 title. The door handles, vent and lack of a side vent on the drivers side of the cowl are the distinguishing clues.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 12-31-2013 at 12:24 PM. |
12-31-2013, 02:11 PM | #9 |
Re: 49 door glass
The vent on the side of the cowl have been welded shut by previous owner. Did the 52/53 have a split windshield?. I just want to make sure I order the correct parts for my build. Thank you guys again for the help
12-31-2013, 02:14 PM | #10 |
Re: 49 door glass
I think wing windows are great.
12-31-2013, 02:23 PM | #11 |
Re: 49 door glass
Yes I want to keep them but I could buy the 1 piece window for what it will cost me to fix the vent window. that was my only thought and with not putting ac in the truck they would be nice to get air in the cab
12-31-2013, 05:54 PM | #12 | |
Re: 49 door glass
LMC and most of the other vendors sell the frames for the one piece windows or you can buy them used. Someone sells the channel that goes in front that the channel that goes around the glass fits in. You have to cut out the metal piece that is below the vent window but that is easy.
