Old 12-29-2013, 01:43 PM   #1
stepsider
stepsider's Avatar
Tail lights
When I bought my truck The PO had installed 4 " truck lights in the fenders. One of the lens was faded, So I wanted to change them out. With 4" holes I was Limted Went to O'reilly's & found 4" LED lights. Had to enlarge the holes to 4 1/2, came with rubber ring grommet. Had to cut the face of the grommet off
& put on the stainless trim rings that I got off ebay. Now the are flush mount. The old lights had a rubber ring around the light about 3/8 thick as you can see by the picture.
stepsider is offline   Reply With Quote
Old 12-29-2013, 01:45 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Tail lights
Looks clean !
Grumpy old man is offline   Reply With Quote
Old 12-29-2013, 02:40 PM   #3
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Re: Tail lights
Looks pretty good. How do they look turned on, I bet they are bright.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 12-29-2013, 06:40 PM   #4
bigmac73
bigmac73's Avatar
Re: Tail lights
what is your plan with the cargo light hole?
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 12-29-2013, 09:31 PM   #5
stepsider
stepsider's Avatar
Re: Tail lights
Looking at LED's on ebay, Lots to choose from. Going to find a bad/used cargo light to modify. 1st picture running lights, 2nd stop light. They are nice & bright.
