Member since 2000
wierd thought- rear suspension coil setup
I was thinkin. would our truck not handle better if the coils sat outside the trailing arms, closer to the axles with a inward tilts kinds like "/" <--saying this would be the left coil?
no because the way the bushings are in the trailing arms they go up and down
![]() Join Date: Jun 2002
Alexis, I've got a magazine at home where they removed the coils and shocks and put coil overs behind the axle. If you want I'll mail the book to you. It's a cool setup.
Roger
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#4 | |
Nope, it ain't back-halfed..
Rg
Member since 2000
i put more thought into put did not type it out. iw ill tonight though so you guys can see what I'm talking about.
Boosted Member
The farther the shock (coilover) is tilted away from being perpendicular to the ground, the less effective it is at damping.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Fabricate till you "puke"
Coil overs on trailing arms..... http://www.classicperform.com/tech_a...coil-overs.htm
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
That's the article!!!
Rg
