12-29-2013, 04:09 PM | #1 |
Need help ASAP
The guy putting my factory bench seats n console is having an issue with the new bucket seat seat belts. He said the location of the bench seat will not work for the bucket seat belt that goes between console n seat. Can anyone help where or how to install this? He can't finish until I can answer this
12-29-2013, 04:29 PM | #2 |
Re: Need help ASAP
post some photos - what year truck? - removing bucket seats and installing bench seat? can't you just move seat belts? what factory bench seat had a console?
12-29-2013, 04:38 PM | #3 |
Truck junkie
Re: Need help ASAP
This is where the buckle belts go. I can try to get better pics but my phone camera lenses sucks. Its one on each side of the hump.
12-29-2013, 04:39 PM | #4 |
Truck junkie
Re: Need help ASAP
If you have a center belt one side bolts to each of the same holes along with the buckle belts.
12-29-2013, 04:40 PM | #5 |
Re: Need help ASAP
Truck is a 71 swb 2wd. Going from bench to bucket seats. I'm not with the truck so I don't have pics. The guy I stalling the bucket seats says the bucket seat belt won't work in the location the bench seat belt is. Does it go in a different location or to the seat bracket. I'm not sure since the truck came with a bench seat. Hope this makes since.
12-29-2013, 04:45 PM | #6 |
Truck junkie
Re: Need help ASAP
Oh that makes it different. It read like you were going the other way. My truck is bench. The problem he has is that the bench seat belts just lay on the seat. If you just installed them that way they would just lay on the floor.
12-29-2013, 04:53 PM | #7 |
Truck junkie
Re: Need help ASAP
Well I just. Checked my 71 it had buddy buckets in it and the belts are in the same place but the seat is gone.
12-29-2013, 05:13 PM | #8 |
Re: Need help ASAP
I went from bench to buckets and used the same belts and mounting location.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-29-2013, 06:01 PM | #9 |
Re: Need help ASAP
I bought the seat belts for bucket seats which has the plastic sleeve that keeps the seat belt straight up that goes between the console and the seat. The issue is the seat belt is 4"-6" short. You can't see the seat belt. Is there an extender that would bolt to the floor and then the seat belt to that? I hope all this makes since.
12-29-2013, 06:30 PM | #10 |
Re: Need help ASAP
Is there anyone on the site that could fabricate me 2 seat belt extenders made out of steal?
12-29-2013, 06:36 PM | #11 |
Re: Need help ASAP
you don't need steel seat belt extenders any real upholstery shop this should be a NON ISSUE use the factory mounts .they should have the simple ability to correct any problems , IE : extend the belt material ?
12-29-2013, 06:58 PM | #12 |
Truck junkie
Re: Need help ASAP
Most upholstery shops wont modify seat belts due to "liability" around here. I have asked several places over the last few years and that was the answer I always got. Maybe he will have better luck.
12-29-2013, 07:08 PM | #13 |
Re: Need help ASAP
You have the wrong seat belts if they are that short. Did you buy them from a vendor that was advertising as for these trucks?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-29-2013, 07:26 PM | #14 |
Re: Need help ASAP
I bought them from Morris Seatbelts. They said they were for this truck. I will call them tomorrow and see what they say.
12-29-2013, 08:02 PM | #15 |
Re: Need help ASAP
71 he is using a set of aftermarket belts with retracted like a late model gm, If had to guess they are three point correct? The buckle / receiver is problem, it is too short. You may try to locate some extenders as mentioned earlier or locate a set of factory belts until you can get the extenders made or located. Even with factory buckets the end you are having problems with will continue to be a problem, the factory console will be in the way. Hopefully Morris seat belts will have the extension you need.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-29-2013, 08:09 PM | #16 |
Re: Need help ASAP
71 super …. you hit the nail on the head...
