12-29-2013, 06:22 PM | #1 |
Junior Member
door to fender fit
Please see pics attached. I have been trial fitting all my sheet metal to be sure that there won't be any surprises after paint. I need input on possible solutions to my fender edge protruding 1/8-3/16" beyond the door edge. The edge of this door has a pretty good curve inward; should I try and remove some of that? Thanks
12-29-2013, 06:49 PM | #2 |
CAN'T FIX NOTHIN
Re: door to fender fit
Start with the doors align them to the back of the cab then move forward and align the rockers then the fenders then the cowl then the hood , may have to cut off the tabs where the body panels bolt on and reweld them or ? Get it all as close as possible then bondo it perfect ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
12-29-2013, 07:21 PM | #3 |
Junior Member
Thank you for the reply. I believe the doors are at the best possible fit to cab and rocker. Did the front of your doors curve inward at the edge near the fender? Did you straighten that out or build it up with body filler?
12-29-2013, 07:29 PM | #4 |
CAN'T FIX NOTHIN
I did a combination of both bending the metal and using bondo ,,,
12-29-2013, 07:56 PM | #5 |
Make sure the door is all the way out where it needs to be (adjustment in hinges).
I believe the curves in the leading edges of the doors are there from the factory to give you clearance for opening and closing the door. Its funny though... my project has it's original doors and the driver's door has a much more pronounced curve than the passenger side. That curve makes it very hard to look at and bring both flush with each other. |
12-29-2013, 09:39 PM | #6 |
I'm restoring two trucks both with original sheet metal and both have that same body line problem. I am going to see what can be done but for now I can tell you that it is normal. John
12-29-2013, 09:44 PM | #7 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-29-2013, 09:57 PM | #8 |
Junior Member
I know these are factory doors but I want to improve on the fit a little at least. I am thinking of trying to hammer/dolly some of that out. Are most leaving that much miss-match?
12-29-2013, 10:07 PM | #9 |
i noticed that your rocker panel has been welded on to far in from the factory.. my 67 has that on the drivers rocker and it seems out rockers are in real good shape with no rust i want the rocker to be out more to match the door and the fender but i just don't want to cut out a good original rocker that has almost nothing wrong with it.. but then it seems there's no other way besides massive amounts of bondo.
12-29-2013, 10:14 PM | #10 |
I've been told by GMC Paul that factory rockers are actually inset 1/8-1/4" from the factory. This came up when discussing fit of repro rockers and how most try to perfect the fit.
12-29-2013, 10:15 PM | #11 |
The Main purpose for the curve is to avoid what we in the "body shop biz" call " lipping the door". That is if or when the door edge is in perfect alignment with the fender and gets too close the best you can hope for is paint rubbing off, the worst you can have is huge damage to the door fender gap area. If anyone ever had a 88-98 Chevy truck and let the door bushings go too long before changing them they know what I mean, I mean really too long not just the regular dragging on the striker plate if left alone the door would even come into contact with the fender and it would get bent. Nobody here that is gonna go through the trouble block or "fix" the gaps, by other means needed on the door to fender on the C trucks of the body style in question here is gonna let anything like that happen. You may be able to dolly it out but I am doubting it. That area is not only doubled there it is thripled there for much of it. It is gonna be hard to move, I have a door that looked real good but had some damage where some one had opened the door and backed into a pole leaving dents on the inside of both sides of the door. I ground it down welded pins tried to pull nothing. welded straps, still not much, So I cut the outer skin off and it moved very easy then. It hammered right out. You just never know.
12-30-2013, 05:48 PM | #12 |
CAN'T FIX NOTHIN
for all you youngins that asked about whether or not the poor panel fit is normal YES it is normal but today we don't like it ! and also other than the edges being lipped in also the gaps were off from the bottom to the top ive seen them almost rubbing at the top or bottom and be 1/2 gap at the other , it is a job to make the gaps on these trucks look good but it can be done ,,, tailgate is the same way ,,,
12-30-2013, 05:52 PM | #13 |
CAN'T FIX NOTHIN
12-30-2013, 06:08 PM | #14 | |
From all the OP's pics, the gaps actually look pretty good. One thing that really helps is to have the body color behind the panels. Nothing makes gaps stand out more than a contrasting color behind the panels.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 12-30-2013 at 06:30 PM. |
12-30-2013, 06:38 PM | #15 |
Junior Member
Thanks for all the replies. Believe me I understand that the original fit of the panels from the factory was no where near perfect; my dad has a '72 GMC that has gaps like 19673ontree and 67Chevy Redneck talk about. However, this one gap issue really sticks out like a sore thumb and I would like to improve it some; all the build threads I've seen don't seem to have this issue.
12-30-2013, 09:13 PM | #16 | |
Nothing is perfect in life and especially these old trucks. FWIW, between bondo and slightly ill-fit I would take ill-fit EVERY day of the week. Best of luck with your build JohnG |
12-30-2013, 09:38 PM | #17 | |
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
12-31-2013, 07:29 PM | #18 | |
CAN'T FIX NOTHIN
12-31-2013, 07:45 PM | #19 |
E.H.F.D Engine #2
Funny i see this thread today, I just spent hours playing with this yesterday. We had everything lined up perfectly before paint, and now trying to get it back is very challenging. And add another fun part into the mix: everything has brand new beautiful paint on it. Very nerve racking. I read something in the thread up top that Ilearned from a body man once. Go from back to front. Get your cab to door gap nice, then do the bottom, then do the top. Then hang the fender and go forward again. It is all much easier on paper though...
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
12-31-2013, 11:04 PM | #20 |
Not sure but in the pic it kinda looks like you fender is bowed out in the middle. Like it needs layed down and flattened. Are the fenders gm or repo, either way I'd try another fender on it and see if its the same before you go to working on the door
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
12-31-2013, 11:29 PM | #21 |
They look to be GM. The repro fenders can be made to look good, but usually have a poor fit where they meet the hood and cowl (usually too "low") His hood/cowl/fender fit looks to be excellent.
01-01-2014, 01:45 AM | #22 |
Junior Member
Fenders, doors, hood, and cowl panel are GM parts. If you place a straight edge across the door and fender, the door is flush with the fender approximately 1-3/4" back from the edge. Drivers side is so much better. To me it looks like the edge of the door on the passenger side is curved in way more than the driver side. I could probably cheat a little and remove a shim from behind the fender but will ruin other gaps. Has anyone flattened the door edge?
01-01-2014, 01:12 PM | #23 | |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
this may be old news to some of you seasoned body guys but it may be helpful to someone new to it. |
