12-30-2013, 09:44 AM | #1 |
cut coil question
So I bought drop spindles.since I had to remove the old ones to put the new ones in , I decided to cut rhe coil .I cut off 1.5 loops off and not it seems to be a bit loose any advice will be greatly appreciated.
82 lwb lsx 5.3/4l60e 12 bolt rear lambo electric blue/ hummer black with house of color flake same colors on the inside with all new upholstery n 22s. " Who said longbeds cant look good " |
12-30-2013, 09:59 AM | #2 |
Re: cut coil question
Define "a bit loose"?
12-30-2013, 10:10 AM | #3 |
When I put the coil in there after reinstalling the drop spindles if I apply enough pressure to ot will wiggle and to say the truth I think thats a big concern I dont want to be hauling ass then my spring fall out
12-30-2013, 10:32 AM | #4 |
Happy to be here
If you put everything back together correctly and the spring is loose in the pocket, then something is wrong. Is it possible that the spring was already cut?
12-30-2013, 10:39 AM | #5 |
The coil won't seat properly if too much was cut off. N2TRUX might be right & there was already some cut off the spring. It should seat w/enough weight but when the suspension extends (like after a big dip on the highway @ 60mph) there is a possibility it can dislodge.
12-30-2013, 11:16 AM | #6 |
No. Its all original except the shocks n rotors n brake pads and ideas on what to so here?
12-30-2013, 11:34 AM | #7 |
Watch out for your cornhole !
Upper control arm bump stops missing ? That will allow the suspension to unload too far.
You'll also need to remove the lower bumpstops. Otherwise they will hit and stop the suspension from compressing enough to fully load the spring. To review, you want upper bump stops but do not want lower ones.
12-30-2013, 11:37 AM | #8 | |
A few possibilities are they're not installed correctly; or they were heated/previously cut; or something else is not OE. Are they loose w/the truck sitting on the ground w/full weight applied?
12-30-2013, 12:04 PM | #9 |
Well I have the truck on jack atands bc I found oout that I have 1 inch rotors not thw 1.25 rotors and I assued I had the 1.25 rotors when I bought the spindles and now I have to change all that good stuff rotors calipers and lines to make them fit do u think that after I put the wheels back on there will fix it ?
12-30-2013, 12:29 PM | #10 |
could b that after 40 years they were sagged and not the original length
sounds like you should buy new springs
12-30-2013, 01:11 PM | #11 | |
12-30-2013, 01:40 PM | #12 |
Is the top of the coil suppose to fo the oppening on the top of the A arm ? Dumb question I know but im trying to figure this thing out
12-30-2013, 02:28 PM | #13 |
Kill Bill...et
The hole in the upper a arm demples down to sit inside the coils of your spring. It'll take a little fenaggling to get it seated right. But as stated before, if there's no load on your suspension, the springs will be loose. Bummer about getting the wrong spindles, but at least you're upgrading your brakes now. Any upgrade I've ever done, was because I more than likely screwed the old one up. Good luck!
12-30-2013, 02:30 PM | #14 |
Top of the coil 'seats' around a d-shaped (formed) opening that is inside of the front crossmember (that's why the top end of the coil slightly tapers).
12-30-2013, 05:04 PM | #15 |
I think you should cut a full coil. Not a half coil. The spring should fit in the packets. A half cut coil won't. I would never cut a coils.
12-30-2013, 07:24 PM | #16 |
So cut a total of 2 I qont bottom out
12-30-2013, 08:06 PM | #17 |
67-72 parts collector,…
2 full coils is DEFINITELY too much!
Never cut more than 1.5 coils.
12-30-2013, 08:13 PM | #18 |
Thats what I wss thinking lolife . Because I had read that you will definitely bottom out and scrap everywhere if you cut two coils
12-31-2013, 09:29 AM | #19 |
it can bottom out & the coils can come loose @ extreme extension.
12-31-2013, 11:43 AM | #20 |
Just don'y cut coils. Buy 1 inch lower springs. If it is to low, and you get a flat tire the control arm will hit the road, and you will be in trouble. I my self would just have 2 and one half inch drop spindles. Then you can use stock shocks.
12-31-2013, 12:01 PM | #21 | |
Happy to be here
I do agree that spindles should be done first, followed by cut coils as needed.
12-31-2013, 12:07 PM | #22 |
I cut the coils to achieve the drop I wanted adding drop spindles I didnt think thetr was a prob since I read alot of threads saying you can cut them just dnt heat them up or cut to much that 1.5 of a coil was the limit
11-05-2015, 10:41 PM | #23 |
I cut 1 coil off my untouched coil springs. the "d" portion sits correctly on the upper control arm, but the lower portion of the coil now does not sit in the lower control arm like it sould........almost looks like the coil has turned counterclockwise.....it makes no sense to me when the upper portion is lined up correctly........any ideas?
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
11-06-2015, 01:55 PM | #24 | |
11-06-2015, 01:58 PM | #25 |
It was cut directly below the original cut end.......I ended up with 1 complete coil minus the cut wheel width.
