12-30-2013, 12:27 PM | #1 |
Emergency Brake Release
Can someone send me a picture(s) of there emergency brake release. Mine appears to be missing the spring that moves the pedal back up when you release pull the release handle.
12-30-2013, 01:07 PM | #2 |
Re: Emergency Brake Release
You mean one under the cab? Mine doesnt have one on the pedal assembly itself.. shy of a small spring to return the release handle. I only have cable guides under the cab as well.
12-30-2013, 01:09 PM | #3 |
Just the springs on the ebrake cables inside the drums I believe..
12-30-2013, 01:12 PM | #4 |
when you pull the release handle does the pedal come up? Mine doesn't unless you pull it up with your foot or hand.
12-30-2013, 01:17 PM | #5 |
What year?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-30-2013, 01:20 PM | #6 |
Yep... returns all the way up. Have you tried adjusting the slack out of your cables under the cab? Make sure your cables that enter the backing plates are free as well.
12-30-2013, 01:20 PM | #7 |
I was assuming 69-72 when you said pedal.. unless I'm missing something. Happens a lot lately.
12-30-2013, 02:00 PM | #8 |
Its on a 71 C-10
12-30-2013, 02:06 PM | #9 |
Mine is a '70.. you can see the spring here.. inside the drums on the brake cable itself
12-30-2013, 02:29 PM | #10 |
thanks. i guess i need to go over the cables all the way back to the brakes
1971 C-10 Short Bed |
12-30-2013, 02:33 PM | #11 |
i would try adjusting the slack out of them first... under the cab on the drivers side. You'll see a cable guide with a threaded rod through it. Support your pedal all the way up, and tighten the cable to remove slack. Just don't over tighten to start pulling the brakes on.
12-30-2013, 02:34 PM | #12 |
They do stretch over time
12-30-2013, 03:31 PM | #13 |
In addition to Molberg's suggestions you'll likely need to lube the cables, they are probably hanging up inside the cable housings.
