Old 12-30-2013, 12:43 PM   #1
atm70chevy
atm70chevy's Avatar
Whats the difference in the doors?
I am needing to replace the doors on my 70 stepside and I've looked in several catalogs and they list 67-71 doors together and 72 doors separately. I think I have found some used doors on Craig's list but I want to make sure they will fit. Is there a difference in the doors from 67-71 to 72 or will a 1972 door fit on the earlier years? Is there a way to tell what year truck the doors came off of? Thanks for any help yall can offer.
atm70chevy is offline   Reply With Quote
Old 12-30-2013, 12:47 PM   #2
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: Whats the difference in the doors?
One thing that's different is that there's a hole on the inside right below the vent window for a screw to strengthen the whole vent window assembly.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 12-30-2013, 12:48 PM   #3
jdalexa84
The 72 has a different inner door panel. It is not made of metal
jdalexa84 is offline   Reply With Quote
Old 12-30-2013, 12:48 PM   #4
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
I think the difference has to do with the door panel and arm rest attachment. I have a 70-71-and 72 in my shop I will try to check it out today. I'm sure someone who knows more will clarify it by then though.
Oldtruckfanatic is offline   Reply With Quote
Old 12-30-2013, 12:54 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
In terms of the actual door "working" on the truck, nothing is different.
As mentioned above, there is a screw hole below the vent for strength, no big deal. I have 72 doors on my 67 right now.
It's been a long time since I swapped mine (used to have 72 door panels on 67 doors before I swapped doors) , but I do think there are different holes for where the door panels attach. You can make either 67-71 or 72 door panels work. The arm rests attach at the same spot using the same screw holes on all doors. You may have to weld up some of the big holes for the 72 door panel clips to use the screws for the 67-71 doors, but you could just always use the 72 door panels, they look cool.
Another thing to note, the door handle and window regulators have a longer shaft for the 72 doors so they stick out of the thicker door panels. You need 72 regulators to use 72 door panels and 67-71 regulators for the 67-71 panels (you can use the longer ones, but they'll stick out too far.)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-30-2013, 01:07 PM   #6
atm70chevy
atm70chevy's Avatar
Thanks for everyone's help! I was worried about the doors not fitting but after reading the responses, I'm not concerned about the fit anymore. I knew someone out there would know the answer!
Old 12-30-2013, 02:02 PM   #7
WIDESIDE72
WIDESIDE72's Avatar
In addition to whats mentuoned above, 67 doors have different angles for attaching the outer door handles.
http://67-72chevytrucks.com/vboard/s...d.php?t=508128
WIDESIDE72 is offline   Reply With Quote
