Old 12-30-2013, 01:43 PM   #1
cclaeys
Front Drum Wheel Cylinder
Trying to overhaul my front drum brakes and got everything apart, only to find that the cylinder that I removed doesn't jive with the replacement. The one removed was attached with 2 bolts, the new one has a hanger/loop that appears to just slide over the post/spring retainer on the backing plate. Just basic 11" drum brakes with the 2" shoes. Seems like everything I read says I have the right part, but is it just a press fit that is held on my the rest of the hardware, nothing is threaded or bolted on? Thanks!
cclaeys is offline   Reply With Quote
Old 12-30-2013, 06:53 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Front Drum Wheel Cylinder
Let me look it up in the service manual...what year?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-30-2013, 07:02 PM   #3
cclaeys
1970 Jimmy - 4x4
Old 12-30-2013, 07:17 PM   #4
cclaeys
cant even find a part number that gives me confidence...I have seen 3/8 opening is required with locking front hubs, but the ones for trucks seem to have 7/16, I wish one time something would be easier than I thought it would be...If I didnt already dump a bunch of money into new ball joints, etc I would just go get a new disc axle and be done with it!
Old 12-30-2013, 07:24 PM   #5
orangek5
orangek5's Avatar
I had the same exact same problem take the old ones to Auto Zone or O'reillys and compare to 1969 Chevy Blazer NOT 1970 GMC Jimmy
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 12-30-2013, 08:17 PM   #6
cclaeys
yep orangeK5 - that was it, should have just done that in the first place, thanks for the help!
